Spyderco Para 3 Lock Bar Tension
AndrewN
Post by AndrewN »
I have recently received a Para 3 for Christmas, and i have an issue with the lockbar. I need to flick my wrist and flip the blade open at the same time to flick it open. Sometimes that doesn't even work. I an positive it is the lockbar, because once I disengage it, the blade moves backwards so freely that it bounces back open partially once it hits the stop pin. Is there a way I can loosen the lock bar without taking the knife apart?
Johnnie1801
Re: Spyderco Para 3 Lock Bar Tension
Post by Johnnie1801 »
dab a drop of grease on the detent ball
Jon
Ric
Post by Ric »
Use it. Open and close it 200times and more.
It will get better after it's broken in.
Which steel is your Para 3?
AndrewN
Post by AndrewN »
Ric wrote:
Wed Jan 02, 2019 11:47 am
My para 3 is CPM S30V
knivesandbooks
Post by knivesandbooks »
A drop of lube and use will break it in. Give it a month.
