I"m thinking about the Para 3 exclusive CF 52100 ..
I think I would like some forced patina
..is this the best way to resist rust?
..is it possible to get a patina going without taking the knife apart?
appreciate any observation from experienced with use.
52100 patina ???
Re: 52100 patina ???
From what I've seen or heard, this steel patinas extremely easily. You may not even need to force it. If you regularly cut some citrus/acidic fruits, salty meats, cook with vinegar...you'll develop a patina quite easily.
15 's in 10 different steels
I forced a patina on the 52100 PM2. I did three 15-minute baths in apple cider vinegar. Between each bath I'd rinse the blade in running water. Oh yeah, I disassembled the knife and forced a patina on the whole blade. I put a patina on an Opinel as well. I just showed the blade into a lemon. I left it in for 15 minutes, cleaned it off, and stuck it back into the lemon. It was a pretty easy affair. I say go for it.
I have this knife (love Para 3s) and have been using it extensively the last few weeks. I dislike patinas and this is my first Spyderco I didn't get new (traded a Kabar choppa with custom leather sheath ). So I took the knife apart to buff out the light patina that formed already and sand /shine the carbon scales. There was some light rust spots around the pivot. ..but everything cleaned up nicely. I'm trying Aegis EDCI on the blade to see how it holds up.
Here's a great video on the PM2 52100 that talks about forcing a patina and proper sharpening afterwards. https://youtu.be/DwjptFJkgms
It's a great knife ...hope you enjoy it.
James
I would avoid doing the pivot area.
I did mine naturally with some red onions. It makes a nice rainbow effect at first but it turns gray fairly quick. I've since polished it off and keep it lightly coated with Vaseline.
- JonLeBlanc
As others have said, you can just use the knife normally for small food prep tasks and it will patina on it's own very nicely. I absolutely love the PM2 52100 for it's supreme sharpness, and I really need to pick up a Para3.
- The Mastiff
Nope. Regular simple maintenance is the best and only real way to resist rust. Patina is a form of rust. The whole idea about forcing a patina comes from people who didn't want to maintain their non stainless knife. Somehow it then developed into people saying they like the looks.It became a fad of sorts much like acid pre washed and torn jeans. :ois this the best way to resist rust?
I personally don't like the look of rust of any kind and don't mind what little work it takes to keep mine shiny. ( clean the corrosive stuff off if present then oil or wax, 2 to 3 minutes all in) We are all different. Don't get the idea that forcing a patina is a necessary thing, or something everyone does. If it is what you like though than it is a good idea....for you. :)
Joe
Everything Joe said. :cool:The Mastiff wrote: ↑Tue Dec 25, 2018 1:21 amNope. Regular simple maintenance is the best and only real way to resist rust. Patina is a form of rust. The whole idea about forcing a patina comes from people who didn't want to maintain their non stainless knife. Somehow it then developed into people saying they like the looks.It became a fad of sorts much like acid pre washed and torn jeans. :ois this the best way to resist rust?
Joe
I’ll pull a carbon steel knife apart to lube in order to prevent it from rusting and save myself heartbreak down the track like the rust you couldn’t see around your pivot. I wouldn’t however, pull a knife apart to rust it in the hope it doesn’t rust.
If it were my knife I’d pull it apart and give the stop pin and blade (at least) a coat of Eezox. With particularly care in and around the pivot and tang, the places you can’t see or access. I’d use a quality synthetic grease, sparingly on the pivot and trust washer, assemble, tune the knife and call it good.
I also believe, if you eat or food prep with the knife it will inevitably discolour naturally (patina) to some extent anyhow, over time. :)
Patina, which is a black “rust” will protect your blade from the really bad red rust. There was a recent post that linked to scientific testing and proof of this. You can safely patina the entire blade, as the patina is so incredibly small that it doesn’t affect the pivot. I’ve done this with white vinegar to three blades in the last week or so. Of the three, one had a slightly gritty action for the first few flips, but this could be attributable to just about anything and it has been glass smooth since.
