Is this edge wear normal?
Re: Is this edge wear normal?
I was going to post a similar post to what pelagic and vivi said. I’d sharpen to 15 deg per side to get to fresh steel and then touch up with a micro bevel as needed.
IMO, S110V is easiest,most effective and makes best use of the steels strengths by finishing with a fairly coarse micro bevel at 400 to 800 grit. Higher grit (finer edge polish) may give a slightly smoother cut in some media, but it doesn't last long and once gone the remaining edge isn't as aggressive as if it had been finished coarser in the first place.
-David
No reason to sell the knife. S110V is awesome, I used the knife all week. And it shaved my arm hair clean on saturday. That is impressive. The tiny micro chip that barely is a chip it’s self was my own fault. I cut in a box going to deep with very large brass, and steel, and copper compression fittings. If it were S30V, it would have just taken the edge clean off without a chip. Well the shiny line on the tip of my edge that contacted the metal still shaves.
If I wouldn’t have hit metal yesterday I’d be going another week with a like new edge, that has never been touched up, or sharpened.
I have a Tenacious. And it really gets on my nerves that it is only effective to slice up cardboard quickly for a few hours. Then it becomes sluggish, and ripping the cardboard with bare hands is just as fast, or faster.
I’m waiting on my angle finder to arrive. It won’t be here until Monday. Then I will use my Wicked Edge for the first time.
“My daily razor blade”
^Wicked Edge guided system^
Edge holding increases as sharpening skills do.tps3443 wrote: ↑Sat Oct 20, 2018 11:35 amNo reason to sell the knife. S110V is awesome, I used the knife all week. And it shaved my arm hair clean on saturday. That is impressive. The tiny micro chip that barely is a chip it’s self was my own fault. I cut in a box going to deep with very large brass, and steel, and copper compression fittings. If it were S30V, it would have just taken the edge clean off without a chip. Well the shiny line on the tip of my edge that contacted the metal still shaves.
Also, lower grit edges work better for cardboard than polished edges. This is true for many EDC tasks. People fawn over that mirror edge look, but it's worse for a lotof things people use their knives for.
Well SiC is slightly harder than VC, so it will cut it, but at how small the carbide grains are on these powdered steels compared to the grit of the sharpening material, it doesn't really matter tbh. Besides stropping with micron sized particles, all low grit abrasives cut the steel matrix itself, not the carbides.
OP, I believe the factory edge on my paramilitary s110v was about 17 degrees. Going 15 is probably your best bet. If you don't like it's stability, you can always easily microbevel from there to 20dps. That's looks like burr to me, I can guarantee the issue will disappear after a resharpening. I hit screws and staples all the time with my knife, never had an issue. If you hit it at 90°, no issue will ever occur, the steel is many magnitudes higher strength and hardness than some random piece of iron.
My S90v Military gets really really small chips, so small that I need a 15x lupe to see them, and I can barely feel them with slicing paper or running my fingernail over the edge . My first sharpening were with Shapton glass, 320, 500 and stroppping with BRKT black and green compound I could get a great edge but that edge didn’t last as long as it does now and it chipped fairly easy. I ordered the CKTG edge pro diamond plates and not only has it made sharpening very easy, but I noticed less and less chipping...I have yet to remove all the micro chips but again, I don’t notice them in any cutting tasks I’m using it for..The edge I’m using now is at 20 degrees per and 1k diamond with some stropping on balsa wood and 1 micron diamond paste..much better edge holding and stability then before..
My chip on my S110V was removed on the bottom of a coffee cup. I couldn’t believe it. It was tiny and wasn’t really much of a chip at all.
I know S110V works best with a toothy edge and a slightly polished micro bevel. I don’t care about mirror edges, I just want pure sharpness!
Tomorrow I’m going to start on the wicked edge after work. Im doing 30 degrees inclusive on 200 grit diamonds, then I will hit it at 600 grit diamonds at 30 inclusive. Then I will move to probably 38 degrees micro bevel with 600 Diamonds and finish with the 10/14 micro diamond leather strop. I will experiment, and try some different techniques. But, I highly doubt I will ever do a mirror edge. I think that takes hours and hours to do.
If I may, I’d like to suggest you set a 30deg bevel with nothing over 600grit then strop very, very lightly on whatever strop you have. I would also strongly recommend you do not strop until you have eliminated any sign of a detectable burr.tps3443 wrote: ↑Sun Oct 21, 2018 8:11 pmMy chip on my S110V was removed on the bottom of a coffee cup. I couldn’t believe it. It was tiny and wasn’t really much of a chip at all.
Use the knife till it needs a touch up and use a micro bevel then.
Happy Sharpening! :)
I don't know why this misconception is getting spread so much. The difference in edge retention between polished and toothy in s110v/s90v is ~10% or less based on tests done by multiple people on this forum/youtube etc. I started liking polished edges on high carbide steels lately, and giving away 10% edge retention is pretty much nothing imho since you get way more flexibility compared to the uses of a toothy edge and the quality of the cuts is better. Also, high carbide steels don't blunt the same way as 52100 or other simple steels do. They don't get smooth and blunt, they get microserations and slowly become less and less aggressive cutting.awa54 wrote: ↑Sat Oct 20, 2018 7:15 amIMO, S110V is easiest,most effective and makes best use of the steels strengths by finishing with a fairly coarse micro bevel at 400 to 800 grit. Higher grit (finer edge polish) may give a slightly smoother cut in some media, but it doesn't last long and once gone the remaining edge isn't as aggressive as if it had been finished coarser in the first place.
What I do like about a 800 grit microbevel finish is how I can get it back to hair splitting sharpness with 3-5 passes on each side on the diamond plate. That's definitely a plus over a polished edge that people should consider. No grit progression needed.
Controlled testing and someone's EDC usage can be quite different. Also, sharpening skill influences results dramatically. Someone that can get hair popping sharp edges off a DMT Extra Course will get different results than someone that needs to go up past 1000 grit to get that level of sharpness.
Lots of variables at play. The best solution is try different grit finishes on your knives, using them how you normally use your EDC. Your results might be different than mine or the next persons.
i see a lot of posts in this forum and ones like this. i know everyone wants to get an edge with with a mirror finish and sharp as a straight razor. i too have been guilty. a knife maker i know had this to say about that. if you need a knife to shave with then by all means put that mirror and razor edge on it. if you don't sharpen to where it can cut with minimal resistance what you need to cut. anything more than that is removing more metal than necessary and shortening the life of the blade.
emanuel wrote: ↑Mon Oct 22, 2018 12:31 amI don't know why this misconception is getting spread so much. The difference in edge retention between polished and toothy in s110v/s90v is ~10% or less based on tests done by multiple people on this forum/youtube etc. I started liking polished edges on high carbide steels lately, and giving away 10% edge retention is pretty much nothing imho since you get way more flexibility compared to the uses of a toothy edge and the quality of the cuts is better. Also, high carbide steels don't blunt the same way as 52100 or other simple steels do. They don't get smooth and blunt, they get microserations and slowly become less and less aggressive cutting.awa54 wrote: ↑Sat Oct 20, 2018 7:15 amIMO, S110V is easiest,most effective and makes best use of the steels strengths by finishing with a fairly coarse micro bevel at 400 to 800 grit. Higher grit (finer edge polish) may give a slightly smoother cut in some media, but it doesn't last long and once gone the remaining edge isn't as aggressive as if it had been finished coarser in the first place.
YMMV, but my experiments with Spyderco S110V lead me to the conclusion that the final degree of polished-edge sharpness lasts for just a few cuts before falling back to the level of "very sharp", where a coarser edge maintains at "cuts like a buzzsaw" for days or weeks of regular use.
M390-ish steels OTOH...
-David
