$142 Ultimate Sharpmaker setup worth it?
tps3443
Re: $142 Ultimate Sharpmaker setup worth it?
Postby tps3443 » Wed Oct 10, 2018 4:32 pm
I’m just ordering the Sharpmaker, and that really popular green strop from knives plus.
Spyderco Military S110V+ Spyderco PM2 S110V
^Wicked Edge guided system^
Daveho
Postby Daveho » Wed Oct 10, 2018 4:47 pm
Personally I prefer the lansky for a cheapie setup that does the job well,
Vivi
Postby Vivi » Wed Oct 10, 2018 4:58 pm
bearfacedkiller wrote:
Wed Oct 10, 2018 1:39 pm
I consider the diamond/CBN mandatory if you don’t have the tools or ability to reprofile freehand and I consider the UF to be optional and somewhat of a novelty. You should be able to whittle hair with just the fine stones. The UF are cool with steels like VG10 and Super Blue but I personally wouldn’t bother using them with S110V.
Agreed.
Certain steels take a high polish better than others.
Either way, with proper technique, hair whittling sharpness is trivial to achieve with the brown medium sharpmaker rods.
The best setup, IMO, is a super aggressive diamond bench stone for reprofiling and repairing a damaged edge, plus the spyderco medium bench stone for the apex.
If you're not inclined towards free hand sharpening, then the sharpmaker + diamond or CBN rods is where it's at.
Use the brown rods for most knives, and the whites for blades you primarily use for push cutting.
If I were to do it over again I'd skip the UF rods and bench stone I bought, and probably my strop too. Fine is polished enough, and in fact is more polished than I want my EDC and other utility knives.
For most knives I prefer the toothier edge the brown rods leave. I have no issues getting any steel in my collection hair splitting sharp right off of them, no strop.
I think some people let themselves fall into a habit of relying on progressing to higher grits and / or stropping to remove the bur. Use a light touch and a consistent angle and you can get an edge free of a detectable burr with the naked eye using the brown rods.
Here's Cliff Stamp getting a nice edge from a brick, to drive the point home:
https://www.youtube.com/watch?v=mSt2mCWGFII
Postby Sharp Guy » Wed Oct 10, 2018 5:14 pm
I bought one of those strops from KP. I tried it a few times....now it sits in a drawer.
bearfacedkiller
Postby bearfacedkiller » Wed Oct 10, 2018 5:36 pm
I strop my Japanese kitchen knives but not really any other knives.
Sharpening is as much art as it is science. You need both. I think the biggest trap is blaming the tools. Cliffs video illustrates that. I can get extremely sharp edges with the medium Spyderco stone. I have turned into a lazy sharpener in a way. I keep my folders very sharp but mostly do it with two stones. A diamond benchstones to set the bevel and the Spyderco medium stone to set the apex. It is quick, easy and effective.
Bloke
Postby Bloke » Wed Oct 10, 2018 5:47 pm
This rings true for me also particularly after I saw a clip you posted using the SharpMaker sitting on a bench without holding or restraining it in any way.
I only use my SharpMaker for touch ups and since I adopted your unrestrained method my end results have improved markedly.
Vivi, I owe you! ;)
ZrowsN1s
Postby ZrowsN1s » Wed Oct 10, 2018 6:13 pm
I have that set up. Diamond or CBN are good as a time saver. Especially for S110V. I have the UF and use it often, and really like it... But it's not super important for s110V. For s110V I'd say 30degree diamond back bevel, 40 degree micro bevel with the fine rods. skip the brown rods, and the ultrafine for now. If you ever get a different steel, like H1 or M390 for example, the UF stones will really make a difference.
I'm also a big fan of strops. I have the KP strop, it works nice. Good for straightening the teeth of the edge after sharpening, use a light touch and a low angle. Although edge trailing strokes on the fine stones can do this as well.
Carrying 3 knives is perfectly normal :D
-Matt
tps3443
Postby tps3443 » Wed Oct 10, 2018 6:56 pm
Should I use a 30 Degree angle in the Sharpmaker for 15/15 degrees on my edge? I hear the Paramilitary 2 is robotically sharpened, so the edge from side to side is pretty consistent at 14-15 degrees each.
Vivi
Postby Vivi » Wed Oct 10, 2018 7:13 pm
15 degrees would work just fine.
Bloke, glad you found that useful!
npad69
Postby npad69 » Wed Oct 10, 2018 7:18 pm
i also have the ultimate SM setup, I'd say buy the diamonds/cbn.. you'll definitely use it. I didn't have much use for the UF stones though.. made me wish I should have bought a good strop and some diamond paste instead
Sjucaveman
Postby Sjucaveman » Wed Oct 10, 2018 7:35 pm
SF Native wrote:
Wed Oct 10, 2018 1:14 pm
I don’t have the ultra fine. Many say they are not as useful. I’m fine without them.
My advice is get the regular sharpmaker. Don’t get the diamond or cbn rods yet. Plan on getting them later but you won’t need them for while. Save a little cost now. Maybe get those rods with a coupon or sale later.
But you're not ultra fine ;)
Adam
tps3443
Postby tps3443 » Wed Oct 10, 2018 7:36 pm
I find it funny, everyone says; I have the “Ultimate Sharpmaker setup too”
Even though I kinda threw in the word ultimate, it really is technically.
Spyderco should sell it all together at a lower cost. And call it;
The ultimate Sharpmaker! Haha
There has literally been several post, “Hey man I’ve got the Ultimate Sharpmaker setup” lol
Postby abbazaba » Wed Oct 10, 2018 7:40 pm
You'll have fun and learn a lot about sharpening with this setup. Watch the DVD and use light pressure :)
SF Native
Postby SF Native » Wed Oct 10, 2018 7:58 pm
You would be correct sir.
Bloke
Postby Bloke » Wed Oct 10, 2018 8:04 pm
That’s because ultimately we’re all Sharp Making Freaks. :eek:
I’d like to see a case, maybe red in colour that stores all the extra rods and clips to the bottom of the SharpMaker case. :)
Users browsing this forum: Ankerson, Bing [Bot], blues, Google [Bot], Lumpy620, TkoK83Spy, vvs and 27 guests
