Dfly Rehab
Hgwxx7
Dfly Rehab
Postby Hgwxx7 » Sat Sep 22, 2018 2:28 pm
Hey everyone! I picked up this user HAP40 Dfly for a decent price, but it's in kind of rough shape. The scales need a good cleaning, any suggestions?
Also, there seems to be a chip in the backlock. Is my best bet to send it into Spyderco for some spa treatment?
Stay Golden :spyder:
cabfrank
Re: Dfly Rehab
Postby cabfrank » Sat Sep 22, 2018 2:41 pm
A toothbrush will work well on the scales. Does the chip cause any functional issues? It doesn't look like it would. I don't think it would be a warranty issue either way. Nice knife!
Hgwxx7
Re: Dfly Rehab
Postby Hgwxx7 » Sat Sep 22, 2018 3:16 pm
Thank you! Correct doesn't seem like a functional issue. Anything in particular with the brush? Soap and water? Something stronger?
Hgwxx7
Re: Dfly Rehab
Postby Hgwxx7 » Sat Sep 22, 2018 3:23 pm
Update! There is a small chip, perhaps .5mm in the base of the edge near the choil. I have a standard sharpmaker. Will medium stones at 20 degrees work the chip out?
attila
Re: Dfly Rehab
Postby attila » Sat Sep 22, 2018 3:41 pm
I recommend 15° for HAP40, but that'd take longer to do the job.
Is the chip 0.5mm in length or depth? Do you have the CBN or diamond rods?
Own: Delica, Old S30V Native, modified Breeden Rescue, Delica, HAP40 Endura, ZDP DF2, S110V Manix LW,Pakkawood Delica, Cruwear Para 3, SE H1 DF2, M4 Manix 2, HAP40 Caly 3, S90V Native 5, K390 Urban, Pakkawood DF2, Cruwear PM2, SE Pac Salt, HAP40 Jazzlica, S110V Native, P.I.T.S., DLC Manix 2, REX 45 PM2, Para 3, XHP Manix LW, SB Caly 3, 20CV PM2, Rhino, SB Calypso Jr., B70P, PMA11, K03, ZDP Stretch 2, Kapara, REX 45 Military, 154CM Manix LW, 204p PM2, Swick, SG Delica, backlock Lil'Native, AEB-L Urban, HAP40 Stretch, KC Cruwear Manix 2, Cruwear Military, M390 PM2, Cruwear Delica, 4V Lil'Native, Mantra 2, CruCarta Shaman, M390 Para 3 LW, M390 Manix 2, K390 Police 4, RexWood Shaman, DLC Cruwear Shaman, Rex 45 Manix 2, Native 5, Native LW, 204p Para 3, S45VN PM2, S90V Manix LW, 20CV Manix 2, Rex 45 Lil’Native, Shaman, C208GP.
Waiting for: SPY27, K490, Swick 5, and something purple
Hgwxx7
Re: Dfly Rehab
Postby Hgwxx7 » Sat Sep 22, 2018 4:08 pm
Hey Atilla! It's .5mm in length. Depth is a fraction a mm. I just have the standard CBN medium and fine rods that come with the SM, and plenty of time to work it at 15!
cabfrank
Re: Dfly Rehab
Postby cabfrank » Sat Sep 22, 2018 4:24 pm
Dish soap and water should do, not too wet.
Re: Dfly Rehab
Postby Evil D » Sat Sep 22, 2018 4:40 pm
I would avoid the corners of the Sharpmaker when dealing with a chip, they seem to just sharpen the chip and create a little mini serration of sorts. If you stay on the flats you should be able to sharpen it out with a little effort.
Cleaning wise I've had good luck with dish soap and a toothbrush but just about any soap and a brush will clean FRN. Barkeeper's Friend and a brush will get it done too.
As for the lock bar chip I have no idea how you'd even do that.
Hgwxx7
Re: Dfly Rehab
Postby Hgwxx7 » Sat Sep 22, 2018 4:46 pm
Haha I was wondering the same thing! The only thing I can think of was that he was mid-deploying the blade and dropped it on its back so the bar was exposed and chipped but the edge/tip were fine.
Re: Dfly Rehab
Postby Evil D » Sat Sep 22, 2018 4:52 pm
I wonder if it's not a defect, seems like maybe it could have happened during a hard opening.
Eli Chaps
Re: Dfly Rehab
Postby Eli Chaps » Sat Sep 22, 2018 8:05 pm
That side shot freaks me out because my backlock is clearly visible above the FRN. If the dent wasn't there and the metal line was constant, it would essentially be a continuation of the handle arc.
Is that just something with the picture?
Re: Dfly Rehab
Postby Sharp Guy » Sat Sep 22, 2018 10:12 pm
I noticed that earlier. I figured it was cropped out of the pic for some reason or they took the pic with lock bar out of the knife.
Daveho
Re: Dfly Rehab
Postby Daveho » Sun Sep 23, 2018 2:07 am
You can save weight on your Dfly if you get it from a totally offical supplier the county of of whose origin I won’t speculate on...
awa54
Re: Dfly Rehab
Postby awa54 » Sun Sep 23, 2018 2:21 am
Looks like a crop that was done with edge detection, the detection threshold was set too low and the shiny lockbar was cropped out of the image area.
But I can't be certain...
-David
Hgwxx7
Re: Dfly Rehab
Postby Hgwxx7 » Sun Sep 23, 2018 4:27 am
LOL I promise this isn't the LW model. It must have been the angle or as others have suggested the edge detection.
The scales cleaned up really nicely and I was able to work the chip out using the medium rods on 15. I followed it up with fine rods and some newspapers stropping. I'll upload an after picture when I can get some natural light to better show it off!
Hgwxx7
Re: Dfly Rehab
Postby Hgwxx7 » Sun Sep 23, 2018 4:32 am
Here is an after shot. Pardon the poor lighting!
Users browsing this forum: AHarbuck, autoxer, Bing [Bot], Diamondback, Google [Bot], Majestic-12 [Bot], negative d, qwkzotc, Sharp Guy, Spydergirl88, TkoK83Spy and 27 guests
