Made a strop
Woodpuppy
Made a strop
Postby Woodpuppy » Sat Sep 15, 2018 10:57 am
Today I made a strop. I was discussing final sharpening using strops with a friend who had about a 1/4 hide and offered up some leather. I had a piece of 1/2 x 2.5” x ?? oak. Perfect! I cut the leather slightly larger than the wood, glued it up with good ol’ Elmer’s rubber cement, then finished it on my bench sander. Now I’ve just gotta wade through all the info and misinfo about abrasive compounds... it’s enough to make my head hurt. I like whatever green compound that came on my Worksharp field sharpener.
I glued it up so I’d have one side suede:
...and one side smooth:
:spyder: My other blade is a Kelly Perfect :spyder:
Eli Chaps
Re: Made a strop
Postby Eli Chaps » Sat Sep 15, 2018 12:18 pm
Good for you!
I always leave the smooth side naked.
To me the abrasive thing is pretty simple. If you're going to strop high-vanadium-content blades, you're best to go with diamond or CBN. Otherwise, whatever compound you like. I really don't think anything below 4um is necessary, fun and cool yes, but not necessary.
colin.p
Re: Made a strop
Postby colin.p » Sat Sep 15, 2018 2:45 pm
I took an unused paint stir stick and glued an old belt to both sides, smooth side out. I haven't needed to use any compound yet, but I can sure get a real sharp edge.
My son used to install hardwood flooring so I have a garbage can full of oak scraps. I'll have to use a piece of flooring to make a larger/sturdier strop some time.
brainfriction
Re: Made a strop
Postby brainfriction » Sat Sep 15, 2018 5:28 pm
Good for you!
Yep, diamond works great on stuff like s30v, s110v, etc.
If you're ever having trouble getting those screaming sharp, hair whittling edges try some diamond compound.
Pelagic
Re: Made a strop
Postby Pelagic » Sat Sep 15, 2018 5:53 pm
2 words.... Ken Schwartz.
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
Woodpuppy
Re: Made a strop
Postby Woodpuppy » Sat Sep 15, 2018 6:32 pm
I’ve used the smooth side tonight on the M4 para3 in the pic and a couple santokus. Took all 3 knives through the brown and white stones on the sharpmaker and finished on the smooth leather. I’m impressed what a difference plain leather makes!
Woodpuppy
Re: Made a strop
Postby Woodpuppy » Sat Sep 15, 2018 6:41 pm
Found his blog... that could be a serious rabbit hole!
Woodpuppy
Re: Made a strop
Postby Woodpuppy » Sat Sep 15, 2018 6:47 pm
Good for you!
I’ll be sharpening whatever Wusthof uses in their classic kitchen knives, 52100, A2, D2, M2, M4, rex45, vg10, 154cm, and hopefully soon some O1. I’ve been pleased with the tiny strop on my worksharp field sharpener, it’s got “green” compound. No idea what grit.
Eli Chaps
Re: Made a strop
Postby Eli Chaps » Sun Sep 16, 2018 8:12 am
Good for you!
Compounds can vary widely and color isn't always a good delineator, but "green" compound is often the very common chromium oxide. It's sometimes mixed with aluminum oxide as well. Grits sizes vary widely. There are those here far more versed in this so I'll let them correct or add to anything I said.
It will definitely handle your Whustof's. I don't even steel anymore, just strop on green suede and then bare hard leather. It'll be fine for 52100, VG10, and 154cm and I think the others but I don't have first hand experience there.
JonLeBlanc
Re: Made a strop
Postby JonLeBlanc » Sun Sep 16, 2018 8:34 am
Nice strop! If you want a recommendation on compounds, I’d say try DMT’s dia-paste, I got a sampler pack of 6, 3, and 1 micron and they work great for honing and polishing! It was not expensive and I still have plenty left in the tubes. They work great on both carbon steels and highly alloyed metals.
Rutger
Re: Made a strop
Postby Rutger » Sun Sep 16, 2018 9:01 am
The branded diamond paste and sprays are pretty pricey. I just bought a whole set from 0.5 up to 40 micron straight from China for a fraction of the price. I did the same for a diamond plate that i use to lap my Naniwa stones.
Holland
Re: Made a strop
Postby Holland » Sun Sep 16, 2018 9:37 am
Nice done, looks great!
Pelagic
Re: Made a strop
Postby Pelagic » Sun Sep 16, 2018 2:51 pm
I'm in the minority on this but I often like stropping with dry diamond powder on basswood. I'll go as coarse as 30 micron. Burr eliminator and aggressive edge.
Woodpuppy
Re: Made a strop
Postby Woodpuppy » Sun Sep 16, 2018 7:50 pm
Thanks all. JLB the DMT sampler pack seems like a good risk.
Bloke
Re: Made a strop
Postby Bloke » Mon Sep 17, 2018 1:17 am
Well done Wp.
I’ve found Dialux Vert (green) works well on leather (flesh side). It’s dry, so as your strop loads up and glazes you can use a clean piece of scrap leather to clean it unlike anything oil based.
I’ve also found that I get best results from sanding the flesh side of the leather on a sheet of sandpaper laid on a flat surface like a granite bench top, sheet of glass or similar till it’s flat and all the “fluffy” stuff is gone.
For what it’s worth I sand the smooth fur side of the leather flat too. I don’t use an compound on that side and only use it to lightly finish and clean residual compound from the blade. :)
All that said the only knives I strop these days are true zero grind Scandinavians. :rolleyes:
Users browsing this forum: Bing [Bot], Google [Bot], MSN [Bot] and 32 guests
