V-TOKU 2 Love
archangel
Re: V-TOKU 2 Love
Postby archangel » Sat Jul 21, 2018 7:38 am
Observation: according to Spydiewiki, the Endura was designed by Sal. There is no respective laser marking on the blade. Why is that?
Michael
Proud owner of 33 spydies (33 different models, 32 different steels) and a Sharpmaker
Missing steels: LC200N, Maxamet, M390, 154, 3V, 4V, AUS-8, GIN-1, ATS-34, ATS-55, 440V/S60V
Lordwilson86
Re: V-TOKU 2 Love
Postby Lordwilson86 » Tue Jul 24, 2018 7:42 pm
Here is mine. Love this knife!
blueblur
Re: V-TOKU 2 Love
Postby blueblur » Wed Jul 25, 2018 6:08 am
I broke down some cardboard boxes last night and was blown away how fast I got it back to hair popping sharp with just the medium rods of the SM. I’m really enjoying these easy to sharpen steels and glad I have a cruwear Manix and a 52100 PM2 to rotate between but lately I’ve been all about the endura!
SolidState
Re: V-TOKU 2 Love
Postby SolidState » Fri Jul 27, 2018 4:28 pm
Am I the only guy with a Delica in V-toku right now? BTW, the Delicas are great! Edited with a pic - because proof is necessary.
Slumblor
Re: V-TOKU 2 Love
Postby Slumblor » Fri Jul 27, 2018 4:43 pm
You have a V-Toku Delica?? How?
SolidState
Re: V-TOKU 2 Love
Postby SolidState » Sat Jul 28, 2018 12:36 pm
I think there was an error at SFO.
Lorelei
Re: V-TOKU 2 Love
Postby Lorelei » Sat Jul 28, 2018 2:32 pm
Nice! :)
bearfacedkiller
Re: V-TOKU 2 Love
Postby bearfacedkiller » Sat Jul 28, 2018 2:34 pm
Saweet! These are about to drop!
Re: V-TOKU 2 Love
Postby Sharp Guy » Sat Jul 28, 2018 2:47 pm
YES!!!!
awa54
Re: V-TOKU 2 Love
Postby awa54 » Sun Aug 05, 2018 9:31 am
Has anyone else had issues with edge damage on thin-ish blade grinds? I'm not even certain what I cut that caused the damage on my Endura, but a 30mm section of the edge had rippled and chipped out at the point where the blade curves up to the point. The edge is at 15DPS with no micro bevel, an edge profile that has worked well for me with other high hardness (though this one feels softer than Spyderco Super Blue or 52100 on the stones) HC steels.
After repairing the damaged area of the blade I'm also no longer quite as impressed with the sharpening characteristics compared with SuperBlue, 52100 or CruWear, it seems to be harder to get a high polish edge on V-toku than those steels, though it does seem to work better with lower grit finishes than the others mentioned.
** it seems like this might have been caused by wire-edge that hadn't separated... while I was re-profiling this morning (had given up on using it as a beater and was in the process of making it the best slicer I could without a re-grind) I found that what looked like a well apexed finished edge, actually had a solid .1mm of flexible "edge" that extended past the supported apex. I knocked it off with the points of the Sharpmaker medium rods and then finished with the flats of the fine rods, the edge isn't bad, but it still needs more work... V-toku isn't responding to my bonded diamond stone progression well at all :( Maybe the next sharpening is going to be a freehand run on the water stones.
-David
Bruce Mack
Re: V-TOKU 2 Love
Postby Bruce Mack » Mon Aug 06, 2018 7:31 am
I find that it does not hold a working edge. After a few uses the edge shreds cardboard or even paper with both push and pull cuts. This is after reprofiling to 15° and many passes on the Sharpmaker.
This is my first Endura. I like the blade length but I will probably toss it if I can't "fix" this problem. I'll first examine the edge for chips with a magnifier and then micro bevel to 20°.
blueblur
Re: V-TOKU 2 Love
Postby blueblur » Mon Aug 06, 2018 3:29 pm
My Endura has some micro chipping in the belly that I first noticed after cutting a nectarine and making contact with the pit. I've touched it up half a dozen times on the sharpmaker (with the 15DPS setting) but can't get those chips out yet. I think I may need to sharpen the bevel which I just haven't gotten around to yet since it takes such a good edge with minimal effort on the SM.
Before this I sharpened the bevel to the 15 deg setting on my EP but I used the primary grind as my anchor point instead of the flat area behind the hole so my bevel is slightly less than 15 deg per side.
I have noticed after cutting any type of fruit or slightly acidic food it does tend to loose a little of the bit. It's been so easy touching up on the SM though it really hasn't bothered me.
awa54
Re: V-TOKU 2 Love
Postby awa54 » Mon Aug 06, 2018 4:18 pm
Interesting that all of the folks chiming in with edge damage have re-set their edge bevels! I'm thinking that the problem is a wire edge that doesn't get cut off of the apex... Bruce Mack and blueblur, try running the blade past your thumb nail or a plastic ballpoint pen with the edge trailing and firm pressure, look carefully for the apex to be bent by that, if it is, then I think we all may have created wire edge, instead of a burr when sharpening.
When I re-re-profiled my Endura (now about 12.5DPS down from 15), I paid extra attention to this and now I don't see that tell-tale deflection when I try to cause it. Time will tell, but I'm not expecting to have the rippled/chipped edge issue again.
I figured out what caused my edge damage, it was debarking and whittling on a small piece of fully dried wood I cut out of an old rose bush, maybe not oak or rock maple, but certainly a dense and hard wood!
On the same subject I have a hand forged V2 gyuto (V-Toku2 is essentially V2 with the addition of tungsten and vanadium and the removal of copper), which rippled badly when I cut a crusty baguette (yeah, there's a reason bread knives exist!), the damage was very similar to what I saw on my Endura, but much less surprising, since it has a typical Japanese kitchen knife grind primary bevel of about 2DPS, with the apexed bevel angle being closer to 4 or 5DPS. Lesson learned: don't cut crusty bread with a razor blade, but if it's a V2 razor blade, expect it to bend before it breaks!
-David
bearfacedkiller
Re: V-TOKU 2 Love
Postby bearfacedkiller » Tue Aug 07, 2018 10:10 am
Mine hasn't hit the stones yet. I just got it yesterday but it will soon!
Here it is with the SB Delica.
knivesandbooks
Re: V-TOKU 2 Love
Postby knivesandbooks » Tue Aug 07, 2018 11:40 am
I've got mine coming in tomorrow. I'm very excited. Love trying new steels.
I own an assisted knife and am embarrassed to admit I enjoy it.
Bruce Mack
Re: V-TOKU 2 Love
Postby Bruce Mack » Tue Aug 07, 2018 5:33 pm
"Bruce Mack and blueblur, try running the blade past your thumb nail or a plastic ballpoint pen with the edge trailing and firm pressure, look carefully for the apex to be bent by that, if it is, then I think we all may have created wire edge, instead of a burr when sharpening."
No expertise here, but I get good cutting at 15 or 20° for a few cuts, then not so good. Would wire edge do this? I'll keep trying. Thanks.
fixall
Re: V-TOKU 2 Love
Postby fixall » Tue Aug 07, 2018 6:40 pm
That’s exactly how a wire edge bur would behave. Super sharp until it folds over.
Deadboxhero
Re: V-TOKU 2 Love
Postby Deadboxhero » Tue Aug 07, 2018 7:20 pm
I'm excited to hear your thoughts off the stones Darby
Big Brown Bear
[url]https://www.youtube.com/user/shawnhouston[/ur]
Triple B Handmade Knives
ZrowsN1s
Re: V-TOKU 2 Love
Postby ZrowsN1s » Tue Aug 07, 2018 7:34 pm
...But what I really want to know is.... Will there be a Wharncliffe version?
Carrying 3 knives is perfectly normal :D
-Matt
Bruce Mack
Re: V-TOKU 2 Love
Postby Bruce Mack » Wed Aug 08, 2018 1:54 pm
Still trying and doing better thanks to you. I could not feel or see (10x loupe) wire edge but after some reading I resharpened on the Sharpmaker, using much less pressure against the rods, also trying to finish using a trailing edge stroke. Then held the blade perpendicular to the softwood base of my strop and ran it lightly from choil to tip to remove any residual wire edge. Then a light stropping after which I disposed of 4 cardboard boxes and sub containers in which $500 of canned cat food had arrived at our home yesterday (lots of cardboard, many cats). This time the Endura did me proud and retained working sharpness throughout the task.
Users browsing this forum: Bing [Bot], Ratamaque and 18 guests
