Forcing a patina on the handle could be a good idea anyway, that would help limit corrosion.ThomC wrote: ↑Sun Jun 28, 2020 12:54 amI meant to write minutes instead of 'more'...because a couple hours would definitely force a patinalegOFwhat? wrote: ↑Sat Jun 27, 2020 12:50 pmWouldn't that force a patina? Wouldn't be a bad ideaThomC wrote: ↑Sat Jun 27, 2020 7:43 amSince you've already cleaned it, for the next time I'd recommend a bath of white vinegar. It worked wonders on the used Millie I bought, as it hadn't been used or properly cleaned in a while. One hour did it for S30V, I'd guess a couple more would do it for a tool steel.
Might be a nice little trial/experiment I can do with two matching PMA11'S. Ordered some Bar Keepers Friend so I should be able to clean up any mess I create. :)
