I just got my Para 3 and if I tighten the pocket clip to the tip-up position, the pivot becomes extremely loose and creates blade play. This is reverted as soon as I tighten the pocket clip.
I assume it has something to do with the screws messing with the metal liners near the pivot... Is this normal? Even if I tighten the pivot as tight as possible, once I put the pocket clip on it becomes loose.
Changing pocket clip to tip up makes the pivot loose
Re: Changing pocket clip to tip up makes the pivot loose
I thought they came tip up?
Yeah that's what I'm thinking. I've seen tip down cause issues around the pivot but I'm not sure how tip up has any effect.
- araneae
Return it, that's not normal.
-Nick
Last in: N5 Magnacut
-Nick
