How much can a DF2 handle?
A couple days ago I only had my DF2 on me and needed to do some strenuous cutting. No abuse, but hard use. After 3-4 minutes of putting a good amount of cutting pressure on the knife there is a little more up and down blade play. I adjusted the pivot back and forth, but it is still there. How much hard use have you put your DF2 through? Can it handle hard use over the long haul?
(I know it is a tiny linerless knife, so I am not expected it to be a fixed blade beast. Just curious of everyone else's experiences with it)
Re: How much can a DF2 handle?
After some heavy cardboard cutting, I noticed my ZDP DF2 had blade play as well, so I don't use it for heavy cutting if other knives are available. My understanding of the vertical blade play is that there are tolerances in the pivot/blade/pivot hole that have opened up a bit during use. The blade/pivot pin tolerances won't change appreciably, but the pivot hole can loosen when there isn't a properly sized steel liner reinforcing it. Of course, that's just how mine changed.
The other thing that I imagine can cause play is if the lock bar and blade interface changes over time. This seems to me like what would gradually happen after years of use (or incessantly flicking it open), not a noticeable change over a short time.
Want: SPY27, K490, Swick 5.
Mine all have a little vertical play. Mine are all also FRN models so I suspect it's just the nature of small linerless FRN knives with very small pivot pins. I would expect the G10 version to be less susceptible to developing play.
never any other issues besides a little up/down play? Never lock disengagement or any sort of failure? (under realistic use scenarios)
ZMW wrote:never any other issues besides a little up/down play? Never lock disengagement or any sort of failure? (under realistic use scenarios)
Nope, I think one benefit is how the grip works, with your thumb on the ramp and your index under the choil, much of the torque is soaked up between your fingers before it ever makes it to the pivot. The blade also being short means you never really apply a lot of leverage to the pivot, compared to how much you could create from say 3 inches away from the pivot on a larger blade. If you're really concerned about strength I'd get the G10 version or maybe check out the Rhino or Lil Native.
A little up-and-down blade-play in Seki City midlocks is the norm (even out of the box), so I understand. My G10 DF2, Police4, several Stretches, and numerous Salts each have it. Hasn't posed a problem in my various light bushcrafting tasks (feathersticking, notching) or in just whittling hardwood (maple, hickory).
-Marc (pocketing a Maxamet Sage5 today)
I have a 1st Gen dragonfly I bought used and carried for years, and still do. It has a broken tip. One day I had to use it to cut many 250lb zipties from around canvas bags and on metal poles. That put a lot of pressure on the pivot. It doesn't have any blade play, which is good since it has a non-adjustable rivet.
The Stainless steel Dragonfly is the most bombproof. My FRN one is free of blade play as well but I baby my knives
I do not have any blade play in any of my many DF's. However, the only one that has had any really hard use has been the G10 and it held up just fine. I think the FRN versions would not be able to handle a lot of stress on the pivot, but the lock should be fine.
- Brock O Lee
My DF2 H1 also developed some extra vertical play after a few harder cuts. The construction should give a hint that it’s a light user...
I have a few DF2s and never had any issues. My ZDP 189 is my most used and is a laser through cardboard and other stuff around the office. I don't need much pressure due to its sharpness and the fact that it stays that way forever. Maybe you need to sharpen it up a bit so it will slice easier and require less force.
But if not, I would vouch for the Lil' Native as stated before. That thing is like my French Bulldog, small but stout and tough!
Dragonfly G-10, Blurple PM2, Para3, Jani-Song, Dragonfly2 ZDP-189, Lil' Native, Chaparral LW, Delica WC HAP40, Para3 M4, HH UKPK S30V, Para3 LW, Para3 LW M390, Meerkat V-TOKU2, M4 Sage 5 LW, Urban Ivory Damasteel, Leaf Storm
-Derek
-Derek
- MichaelScott
I wouldn’t be surprised by this if the knife is used beyond its design expectations. None of my Dragonflies had any blade play whatsoever.
http://acehotel.blog
Team Innovation
Team Innovation
Does the blade move with the back-lock?
With the exception of the Triad Lock, there is at least a possibility of some movement of the blade/lock moving a little in hard use with a back lock due to the design. It does not have a stop pin (except for the Triad Lock). It is, however, the strongest lock type, even so.
