I have had this thing since they dropped and it has had lock stick that just won't go away. It has been cycled probably thousands of times and still sticks, no matter if opened slow, or flicked. I've tried the usual remedies (wash, lube, pencil lead), but everything is temporary. If I blow on the tang cutout, it is perfect for one or two flicks, but then sticks hardcore.
I know lock-stick has been talked about in A LOT of posts, sorry to post another...
Sticky Para 3 S110V
- BrianMcCord
Sticky Para 3 S110V
-Brian
Son's Collection: H1 Rescue Manbug, Tenacious
Rescue 79mm Orange, Cat BD-1, Effecient, Pingo Orange FRN, T-Mag, Urban K390, Lil' Native, Sliverax, Para 3 S110V, Caly 3 HAP 40, R Nishijin, Mantra, Manix 2 LW S110V, Manix 2 Black, Delica 4 Black, PM2 Digi, PM2 Black, Yojimbo 2, Native 5 LW, Dragonfly 2, Military 204P, Wolfspyder, Techno, HAP 40 Ladybug, H1 Hawkbill Ladybug, Blue Persistence, Bradley 2, UKPK SE Gin-1
Looking for an Operation Iraqi Freedom and Operation Enduring Freedom Native. :spyder:
Re: Sticky Para 3 S110V
Rotate the stop pin... It may have a rough spot that "binds" the lockbar, or it will minutely alter the geometry enough to bring the mechanism back in line for smooth operation.
- BrianMcCord
I'll give that a go, thanks mattmanmattman wrote:Rotate the stop pin... It may have a rough spot that "binds" the lockbar, or it will minutely alter the geometry enough to bring the mechanism back in line for smooth operation.
-Brian
Before you rotate the stop pin, there's one more possible easy fix. Grab a piece of wood (2x4) or similar and spend a little time cutting hard into the wood. I've had several sticky PM2s cured with this.
David
David
