Either/both. Neither will do it any harm provided you allow it to dry.DCJ wrote:Many thanks for the responses. ChrisinHove - When you say give it a flush, just running water or some cleaner (soap), too? May try canned air if I have any handy.
Have you ever had a white film spray out of the can of air? We used to keep these on the engine to blow out problematic smoke detectors, and every once in a while, some of the propellant would spray out and coat the mirror inside the detector with a white film.Spydergirl88 wrote:I have the exact same knife and at first it was gritty. canned air sprayed at each side of the lockbar while the knife is half open and at the pivot fixed the grittyness. knife is smooth as glass now
only time that happens to me is if the can is almost empty and the white film quickly disappears bc its frost? idk it's cold lolBrianMcCord wrote:Have you ever had a white film spray out of the can of air? We used to keep these on the engine to blow out problematic smoke detectors, and every once in a while, some of the propellant would spray out and coat the mirror inside the detector with a white film.Spydergirl88 wrote:I have the exact same knife and at first it was gritty. canned air sprayed at each side of the lockbar while the knife is half open and at the pivot fixed the grittyness. knife is smooth as glass now
Maybe it was brand specific...?
I have a small 3 gallon air compressor that I use, but I am also a fan of compressed air...especially after washing in water.
Do you have access to an air compressor? I used one with just my blow gun attachment on it for my last caly. I blew the crap out of it. Mine arrived very gritty. I was shocked how many metal shavings came out of the pivot. Flushed with water, hit it with the air again and more came out. After water flush I let a hair dryer sit on the pivot for a minute to assure no water left behind. A few drops of oil and the pivot was like butter. Good luck.DCJ wrote:Any other suggestions would be greatly appreciated.
If not I have used a gas station tire inflator (to dust off after workSpider bite wrote:Do you have access to an air compressor? I used one with just my blow gun attachment on it for my last caly. I blew the crap out of it. Mine arrived very gritty. I was shocked how many metal shavings came out of the pivot. Flushed with water, hit it with the air again and more came out. After water flush I let a hair dryer sit on the pivot for a minute to assure no water left behind. A few drops of oil and the pivot was like butter. Good luck.DCJ wrote:Any other suggestions would be greatly appreciated.
Users browsing this forum: Airlsee, Bing [Bot], Blnd, Google [Bot], kennethsime, ladybug93, PeaceInOurTime, sal, Skinner, TenGrainBread, TomAiello, Tommyudo, Woodpuppy, yablanowitz and 55 guests
