elena86 wrote:Wharnie Delica in SE is a terrific riper.Your best bet IMO.
I agree with these guys.Evil D wrote:Unless you need the corrosion resistance you may not notice the difference between edge retention. The biggest difference can be found in blade grind, if you can find a Delica in FFG/SE it will slice far better than the Salt. The current Delica wharnie is offered in FFG/SE.
Agree with the aesthetics of the Salt 2, it's a good looking knife. Native 5 is not an option because i'm looking for a thinner blade (2.5mm).zhyla wrote:That's an interesting question. You will hear that H-1 is amazing in SE. I have no H-1 experience but I feel like if it were superior to VG-10 they would be rolling it out in non-Salt knives.
I like the Salt 2 aesthetically.
Probably a better choice than either would be a Native 5 FRN SE. FFG is a big win against cardboard and S35VN is a great steel.
Delica with FFG/SE will be an awsome knife. Not available as far as I know though. I Belief the wharnie will be an awsome knife as well but I'm not a fan of the blade shape. I Did see there is a Dragonfly in VG-10 FFG/SE. Sadly not an option because I carry my knifes tip down only. Personal preference can be a ***** sometimesEvil D wrote:Unless you need the corrosion resistance you may not notice the difference between edge retention. The biggest difference can be found in blade grind, if you can find a Delica in FFG/SE it will slice far better than the Salt. The current Delica wharnie is offered in FFG/SE.
Wharnie Delica ffg/SE IS AVAILABLE !johnson wrote:Delica with FFG/SE will be an awsome knife. Not available as far as I know though. I Belief the wharnie will be an awsome knife as well but I'm not a fan of the blade shape. I Did see there is a Dragonfly in VG-10 FFG/SE. Sadly not an option because I carry my knifes tip down only. Personal preference can be a ***** sometimesEvil D wrote:Unless you need the corrosion resistance you may not notice the difference between edge retention. The biggest difference can be found in blade grind, if you can find a Delica in FFG/SE it will slice far better than the Salt. The current Delica wharnie is offered in FFG/SE.
OP isn't asking for a wharncliffe blade though.elena86 wrote: Wharnie Delica ffg/SE IS AVAILABLE !
Users browsing this forum: bbturbodad, Bing [Bot], Deadboxhero, Doeswhateveraspidercan, MSN [Bot], mugwump867, Notsurewhy, Oogie, redhawk44357, Spydergirl88, SteveMidwest and 60 guests
