Let's get hyped for the Amalgam!
gundamaniac
Re: Let's get hyped for the Amalgam!
Postby gundamaniac » Tue Jan 29, 2019 9:17 pm
Liquid Cobra wrote:
Sat Jan 19, 2019 8:29 pm
I can’t stop carrying this knife. It’s just too fun.
Gorgeous photo. Where is that?
Re: finger eating flipper: I typically pushbutton my flippers if possible (habit from owning a lot of flippers with so-so action, pushbuttoning practically guarantees a successful opening for me). But with the final lock placement where it is, I lightswitch the Amalgam. For me, pushbuttoning the Amalgam results in the painful jabbed index finger pads you're describing, but lightswitching works just fine (or maybe I'm just used to it now haha).
Liquid Cobra
Postby Liquid Cobra » Tue Jan 29, 2019 11:42 pm
Pitt Lake in British Columbia. :D
Most recently acquired: Native Chief, Shaman S90V, Para 3 LW, Ikuchi, UKPK, Smock, SUBVERT, Amalgam, Para 3 CTS-XHP, Kapara, Paramilitary 2 M390
@liquid_cobra
curlyhairedboy
Postby curlyhairedboy » Wed Jan 30, 2019 7:29 am
I'd say that reliable lightswitch action is the sweet spot that I aim for when doing detent tuning. :)
EDC Rotation: PITS, Shaman, CF S90v Shaman, Ikuchi, Amalgam, CruCarta Shaman, Lil Native, Sage 5 LW
Always in Pocket: Hawkbill Dragonfly 2 H1
Special and Sentimental: Southard, Smallfly G10, Squarehead LW, Calendar Para 3 LW, 40th Anniversary Native
Would like to own again: Sheepsfoot Caribbean
Wishlist: CQI Kapara, Watu, Tanto PM2, Shaman Sprints!
gundamaniac
Postby gundamaniac » Wed Jan 30, 2019 12:56 pm
I'm agree that the sweet spot is a nice lightswitchable flipper. My tendency to pushbutton flippers when possible was really to make up for shortcomings, whether it was an overly light detent or stiff pivot or too light of a blade. A flipper had to have pretty bad action for me to need a wrist flick. So I'm pretty happy with the way the Amalgam is easily lightswitchable without wrist as long as it's flipped with any kind of authority (a couple of my friends and family can misfire almost any flipper I hand them because they always only apply juuuuust enough strength to break the detent, or, in the case of my 7777, if the detent is too strong then they can't open it at all :p).
curlyhairedboy
Postby curlyhairedboy » Wed Jan 30, 2019 2:40 pm
I've also noticed "finger creep" which might be my body's reaction to using flippers for quite some time now.
A flipper detent that seems "just right" to my right index finger seems monstrously strong when flipped with any other finger on that hand. It even feels a little strong to my left index finger
I'm not sure whether my other fingers are weaker and not used to pressing things individually, or if index fingers are stronger in general...
I always have to remember that detent is only part of the flipping action equation, and the other portion is the physiological "springs" of our finger tendons.
spyderg
Postby spyderg » Wed Jan 30, 2019 9:21 pm
So I’m typically the guy asking for a stronger detent. I was thrilled with my Cruwear PM2 having twice the detent strength of my older black coated s30v version. The main reason I don’t carry my Gayle Bradley often is a weak detent. But my most recent Spydies have been the Rhino and the Amalgam. Both have somewhat light detents, but near perfect action. Neither blade comes out when I don’t want. It takes a good shake or wrist snap to pop either out. I have nitpicks on pretty much every knife but at the same time can appreciate a good build, and imo the Amalgam is a great knife. Nitpicks maybe but no complaints, even about the detent.
Reference_Sensor
Postby Reference_Sensor » Sat Feb 23, 2019 5:08 am
I've been wanting a bigger Spyderco for some time, but was never able to find one that really "spoke" to me, until now. Just placed an order for an Amalgam, and can't wait to get my hands on it. I'm currently working in Afghanistan, and I've bought a new Spyderco prior to every deployment for the last 16 years. This one is a departure from my usual, the old reliable Endura, but I have high hopes for it. This place is hard on equipment, and I'm eager to see how the Amalgam stands up to use in the harsh, dusty and sometimes dangerous environment of this mountainous region.
"let a man never stir a step on the road without his weapons of war, for unsure is the knowing when need shall arise of a spear on the way without." Havamal, verse 38
gundamaniac
Postby gundamaniac » Wed Mar 06, 2019 12:36 am
Thanks Reference_Sensor! Definitely let me know how you like it when you get it in hand, and keep us posted on how it holds up in your work =). I'm curious how the bearing pivot will do with dust and sand.
curlyhairedboy
Postby curlyhairedboy » Wed Mar 06, 2019 9:47 am
I can say with a high degree of confidence that the Amalgam is very well built after some 'out there' usage last weekend.
Reference_Sensor
Postby Reference_Sensor » Thu May 23, 2019 6:43 am
The Amalgam is holding up quite well so far. Spring has sprung in Afghanistan, and the roses they grow here are in full bloom!
Drmnez
Postby Drmnez » Fri Jun 14, 2019 6:33 am
does anyone know of where I can get some black g10 scales for this bad boy? All my other SpyderCo's I rotate through have those scales and I want my amalgam to match
ferider
Postby ferider » Sun Oct 20, 2019 6:09 am
wrong thread.
gundamaniac
Postby gundamaniac » Sun Oct 20, 2019 12:41 pm
Yesterday, I had access to a Rockwell hardness tester, so of course I took apart the Amalgam I had on me to try it out. I was pleased to see a reading just over 61 HRC on my sample. Woo! 😛
I didn't take a reading just behind the edge because my understanding is that the sample being tested should be mounted perpendicular to the indenter, and I didn't have an appropriate anvil that would allow me to mount the blade so that the flat grind would be properly perpendicular to the indenter.
Edit: last two images didn't upload properly, re-uploaded them
curlyhairedboy
Postby curlyhairedboy » Sun Oct 20, 2019 1:19 pm
Nice! Consistent hardness is one of the big reasons why I'm a fan of spyderco's s30v. It's dependable!
elena86
Postby elena86 » Sun Oct 20, 2019 1:26 pm
IMG_20191019_144306-01-01.jpeg10_20_19_11_04_41_IMG_20191019_144233-01.jpegIMG_20191019_144306-01-01.jpeg
Nice ! Hey Brian could you measure the thickness behind the edge... I am quite confused ...
Marius
" A mind all logic is like a knife all blade. It makes the hand bleed that uses it " ( Rabindranath Tagore )
Users browsing this forum: Airfaye, Bing [Bot], driftingfir, DTPrime, Google [Bot], Hobnob, JMM, Johncjeff, MSN [Bot], skeeg11, SLOSpyder, Spydergirl88, Theldraskien and 21 guests
