Folks,
Is it just me or can you also seem to get VG-10 sharper on the sharpmaker. I have sharpened a Benchmade 705 with 154 and my new Navigator with VG-10 and the Nav seems to me to be a whole bunch sharper. I'm not sayin it ain't operator error cause that would be more likely than anything else. what do ya think. have you experienced anything like this. thanks for the forum. dtsoll
Thank you to those who Serve and Protect.
VG-10 vs. 154CM sharpening
Dt, I have the same thing happen, seems VG-10 responds to diamond sharpeners the best.
Also in the Navigator check the Rc, it runs a full 2 points higher on that model.
If I took all the money I've spent on various sharpeners I coulda bought 10 Sharpmakers instead.
My B/D is soon and that's what the wife is getting me w/ all the goodies.
Bear in mind I chose that over tickets to see the Dixie Chicks at the Bi Lo center <img src="sad.gif" width=15 height=15 align=middle border=0>
154-CM and ATS-34 are both great steels and I can make all of them shave hair, BUT the VG-10 I can make so scarey sharp the hair just gives up and jumps of my arm <img src="smile.gif" width=15 height=15 align=middle border=0>.
I'm waiting on a <img src="spyder.gif" width=15 height=15 align=middle border=0> model with D-2 to come out.
Maybe a BT coated Lum in D-2 and CF scales, that would be sweet. Ron
Remember our lost friends fondly
Ive found in the past that blades of ats34 and 154cm sometimes do better when left with a toothy edge like from a fine diamond or fine india stone and do not like a high polish which you get from a ceramic fine,also Benchmade usually runs a thicker flat grind verses a thin hollow grind that spyderco puts on most of their folders,try putting a higher grind on your 705
- vampyrewolf
