Greetings, one and all.
I have a Spyderco fine ceramic file set, and I love it - the shape of the files permits me to sharpen odd shaped and smaller blades, including serrations.
My only whine is that the files are small, and hard for my fubar fingers to grasp. I'm thinking the larger slipstone might give me some of the sharpening ability I need, while giving me a huge boost in size that I definitely need.
Does anybody know if the two stone sets are equivalent abrasives?
Fine Grit Ceramic Slip Stone v. Fine Ceramic File Set
Re: Fine Grit Ceramic Slip Stone v. Fine Ceramic File Set
I've also got both sharpening tools as well and I've had really good results with them too. I use my Spyderco fine Slipstone much more than I do the Spyderco ceramic file set. A lot of people ignore them because of their small size but I've found that there are a lot of things you can do with them because of their smaller size and versatility.
I've used that Slipstone a couple of times to sharpen some serration patterns and it worked quite well. I've also used the Slipstone to sharpen a linoleum knife with good results as well. I love all of Spyderco's sharpening tools and I've found all of them to have great uses for all kinds of sharpening jobs.
Hi RL,
A 1/2" dowel about 5" long with a 1/4" hole in the end about 1" deep, might work as a handle for the ceramic files?
That's interesting>> I never even thought of having some type of file handle on those little ceramic files but the more I think about it the more I would like to do that to one of my sets of those 400F files.sal wrote:Hi RL,
I'm wondering if one of these tool companies might carry file handles for files that small? Also I've been wondering when the base unit for the GOLDENSTONE might be coming to market?
Hi JD,
The protos are done on the Golden Stone base. First the Gauntlet (which we're waiting for production), then the Galley V, then the Golden Stone base.
Thanks Sal. Just to be "that guy" what is your take on machining a metal handle with a set screw, and using a piece of old bicycle inner tube between the set screw and the ceramic to prevent breakage / cracking from overtightening?
I'm trying to teach myself basic machining techniques, and figure this is a productive little project.
Sounds like a fun project. Should work well.
That is great news Mr. Glesser and I'm anxiously awaiting all of those units to hit the market>> because I make it a point to buy every sharpening tool that Spyderco makes. The only ones I don't have to date is the larger Ultra-Fine stone or the Doublestuff 2 but both of them are on my list to get.sal wrote:Hi JD,
Any more news on the Sprint Run of the 701 Profiles? Hopefully in more grit selections too? That 701 Profile is such a genius tool and I use my sets for all kinds of metal working and knife maintenance. I truly believe every machinist on the planet should own a set of 701 Profiles.
