Back Lock lock material
Can anyone tell me the steel used to make the lock on lock backs? Knife I am specifically looking at is the Civilian. Blade is VG-10.
Thank you.
Thank you.
Re: Back Lock lock material
I think Sal would tell you that it is 'proprietary' and so it is a secret.
However, you might contact some custom makers and ask the question. Probably over on the knife makers sub-forum on Bladeforums would be a good place.
- The Deacon
Or, it may be that Spyderco does not specific particular steels for parts other than the blades, just that the steel meets certain requirements. So the maker may have used more than one steel for the lockbar over the production life of a knife that's been in production as long as the VG-10 Civilian.Doc Dan wrote:I think Sal would tell you that it is 'proprietary' and so it is a secret.
- Stuart Ackerman
Interesting subject...
Last edited by Stuart Ackerman on Tue Oct 17, 2017 1:19 pm, edited 1 time in total.
- bearfacedkiller
On the non stainless steel knives the lock bar is always still stainless. I doubt that the lock bar is ever the same steel. I also do not think that it is a hardened heat treatable steel. It is most likely a high toughness and very low carbon stainless steel that is extremely corrosion resistant. It doesn't have to hold an edge so you can focus on an entirely different group of steels that have the attributes you want.
Interesting discussion on lock bar:
http://m.youtube.com/watch?v=HeXhWAqwqCQ
Chris :spyder:
Sometime back I asked Sal, here on the forum (or maybe BF) this question about the lock bar steel on the Salt series and he responded that it was proprietary.The Deacon wrote:Or, it may be that Spyderco does not specific particular steels for parts other than the blades, just that the steel meets certain requirements. So the maker may have used more than one steel for the lockbar over the production life of a knife that's been in production as long as the VG-10 Civilian.Doc Dan wrote:I think Sal would tell you that it is 'proprietary' and so it is a secret.
I don't actually know how Spyderco addresses this question or whether or not they do the same thing with every back lock model. I'm very interested to see if we hear from Spyderco about how they actually approach this question.
Here's my 2 cents...I've made a few back-locks recently (dang, they're hard to make..just sayin') and had to figure out the best course of action regarding that very question. After a little trial and a lot of error...then finding out how some of the most experienced custom makers do it, I finally got it working nicely. The main issue of concern with the lock bar is that you don't want the interface between it and the blade to wear on each other. For that reason I chose to use the same steel as the blade and heat treated the lock bar with the exact same protocol as the blade. This worked beautifully.
The lock base (part that holds the spring) is a different story. If the base is as hard as the blade it is likely to break under the load of the spring...ask me how I know :D . I used the same steel for the lock base (primarily for corrosion resistance reasons, although another steel could have been used here) but the heat treat protocol for the base was completely different. The target hardness for the base was 53-54 as opposed to the blade and lock bar which were 59-60.
Chad
Chad
@ckc_knifemaker on Instagram.
It sounds like that method would be ideal for most "conventional" steels (VG-10 certainly fits that description) but high carbon steels (assuming you want a maintenance free lock bar), laminates and ultra high hardness or high carbide steels probably won't work as well with a lock bar of the same alloy and HT... I'd assume that in cases like that either a more resilient HT or a tougher/more corrosion resistant alloy would be selected for use with blades that have extreme characteristics.Xplorer wrote:I don't actually know how Spyderco addresses this question or whether or not they do the same thing with every back lock model. I'm very interested to see if we hear from Spyderco about how they actually approach this question.
Chad
-David
You bring up a good example of how material selection in a knife design can get complicated. With the types of steel examples you mention the considerations can become more nuanced, mostly for corrosion resistance reasons in this case. Balancing maintenance with wear and other factors gets into the small details of each particular steel. A steel's degree of corrosion resistance, ability to reach a specific HRC, response to H/T variables, toughness vs wear resistance, etc is different for each steel. Each steel choice will bring it's own limitations to the design and there will usually be more than 1 set of variables that will work in the end. Which variables one chooses depends on the designer's priorities with regard the specific trade-offs they face.awa54 wrote:.... but high carbon steels (assuming you want a maintenance free lock bar), laminates and ultra high hardness or high carbide steels probably won't work as well with a lock bar of the same alloy and HT... I'd assume that in cases like that either a more resilient HT or a tougher/more corrosion resistant alloy would be selected for use with blades that have extreme characteristics.
I dissambled my Civilian yesterday. There was some staining on the lock bar itself. Not much, but enough to discolor the scale.
It would not be unheard of to use the same steel. HT can be adjusted to the proper characteristics. The 'spring' is a much smaller, round in cross section bet steel connecting the front and back portion of the lock. I would guess that is another steel entirely.
Just curious. Thanks for the input.
Hi Gunsandknives,
Welcome to our forum.
As mentioned, that's not info that we like to give out. I will say that it depends a lot on the steel in the blade (different steels require different lock materials), the type of lock and interface, and hardness (they're all hardened Darby).
- bearfacedkiller
Thank you Sal. You learn something new everyday! :) Thanks for sharing.
I had read more than once where custom guys had said that they did not harden them but had also read where others had said that they did. I was just speculating based on the different opinions I have heard.
Thanks everyone.
Not trying to look up Spyderco's skirt. Just curious. Took it apart, started to look over the parts, trying to determine how they are manufactured, how they interact, etc..I will clean it up with some emery cloth.
Just imagine ZDP-189 lock bars at Rc 67 :eek:Xplorer wrote:You bring up a good example of how material selection in a knife design can get complicated. With the types of steel examples you mention the considerations can become more nuanced, mostly for corrosion resistance reasons in this case. Balancing maintenance with wear and other factors gets into the small details of each particular steel. A steel's degree of corrosion resistance, ability to reach a specific HRC, response to H/T variables, toughness vs wear resistance, etc is different for each steel. Each steel choice will bring it's own limitations to the design and there will usually be more than 1 set of variables that will work in the end. Which variables one chooses depends on the designer's priorities with regard the specific trade-offs they face.awa54 wrote:.... but high carbon steels (assuming you want a maintenance free lock bar), laminates and ultra high hardness or high carbide steels probably won't work as well with a lock bar of the same alloy and HT... I'd assume that in cases like that either a more resilient HT or a tougher/more corrosion resistant alloy would be selected for use with blades that have extreme characteristics.
-David
I’m digging into this and after some inspection.. the lock bar running the 3/4 top of the knife look a lot different when I’m actually looking for difference. Grain isn’t uniform and it’s a good shade lighter/brighter then the ZDP189 blade.
But.. does this lead to issues down the line? Say I’m easy on it but open and close it a lot.. will that insanely hard ZDP189 eventually eat away and weaken the inferior lock?
If someone knows for real it would be nice to put this one to bed. We all wanna know and as far as I can tell we’re going off anecdotal answers from custom knife makers that hang in the forums. I wanna know from an engineer at Spyderco.
Dear EnduraNCE:
Although this is an old thread, the definitive answer, per Sal, is in here and is still the same:
"I will say that it depends a lot on the steel in the blade (different steels require different lock materials), the type of lock and interface, and hardness..."
Stay safe,
Mike
Stay safe,
Mike
Hi EnduraNCE,
