Lock Bar Help
40mm
Lock Bar Help
Postby 40mm » Thu Aug 17, 2017 6:46 pm
I had some weird movement in the pivot of my Dragonfly, so I took it down and put it back together. Action is great now and wobbly click is gone, BUT, now when the knife is open the lock bar is sticking up a bit. It's completely flush when the knife is closed. Did I do something wrong or can I adjust it so this doesn't happen??
Imageimage by Six Pound Cat, on Flickr
Re: Lock Bar Help
Postby Doc Dan » Thu Aug 17, 2017 7:08 pm
It should not stick up like that. I once had a Case that did that. I gave it a tap and it went into place. After a few times of that, it settled in nicely. However, it is probable that you have something installed wrong.
(Roy Rogers)
Bloke
Re: Lock Bar Help
Postby Bloke » Thu Aug 17, 2017 7:29 pm
I couldn't be certain because I've never taken a DF apart but from memory I think the spring bar in my Stretch could go in back to front. I put it back the way it came out and didn't have an issue but perhaps yours went in back to front.
40mm
Re: Lock Bar Help
Postby 40mm » Thu Aug 17, 2017 7:32 pm
Yea the spring is the only thing that can be installed incorrectly as far as I can tell. I'll flip it and see but I think it's in the correct way. Hmmmmm
Bloke wrote:I couldn't be certain because I've never taken a DF apart but from memory I think the spring bar in my Stretch could go in back to front. I put it back the way it came out and didn't have an issue but perhaps yours went in back to front.
toomzz
Re: Lock Bar Help
Postby toomzz » Fri Aug 18, 2017 2:53 am
Also my first thougt! Is the tang all clean? No bits or pieces between it and the lockbar?
Re: Lock Bar Help
Postby Evil D » Fri Aug 18, 2017 7:26 am
Make sure the screw in the lock bar isn't too tight.
40mm
Re: Lock Bar Help
Postby 40mm » Fri Aug 18, 2017 8:13 am
That's exactly what it was. Started messing with it last night and realized I had it cranked down really tight. Thanks Evil!
Evil D wrote:Make sure the screw in the lock bar isn't too tight.
Bloke
Re: Lock Bar Help
Postby Bloke » Fri Aug 18, 2017 4:54 pm
Ah, hahaha! :rolleyes:
Users browsing this forum: Bing [Bot], Buddafucco, chops688, DigDug72, DrawBackwards, Enactive, Mushroom, odomandr, Robbob, Shaggy Dog, StuntZombie, WRB and 43 guests
