I will just get things rolling with pics and some commentary inserted with them.
First some comparison pics. I posed it with the Kiwi4 and Yojimbo2 because they are my only other black G10 knives and that is because they have only been offered in black G10 or PPCF which I do not like either. I really do not like black knives myself. See, I started off with a dislike.
Here are a few pics to show the thickness (or thinness) of the Police4 compared to the Military and the Caly3. It is similar in thickness to the Caly3 but the Caly3 has such proud screws that it is hard to line them up just right for a picture. The handle and the blade on the Police4 are both nice and thin. It carries well and slices like crazy. That said, with a 4.5 inch blade that is 3mm thick and ground nice and thin it is not a pry tool. This thing is made for cutting. Seriously though, if this one can be screw construction then why can't the Caly3/3.5. The similarity is obviously there. Maybe it is that they are from different makers?
Here is a pic of the tips being exposed on the Military and the Police4. If there is one thing that both the Para2 and Military have in common it is a lackluster blade to handle ratio. The Police4 does a great job of fitting a ton of blade into the handle. By my measurements the Police4's handle is only about 1/16 of an inch longer if that yet is fits 1/2 inch more blade into it. The Police4 also has the hump on the tip like it's other Seki brothers. While I do not care for that feature it is an easy fix and with the tip being so acute it makes sense to ship them this way. Some like the tip buried a little deeper for safety reasons and this one isn't but I could not get my finger pad to catch the tip even when pressing it in there pretty hard.
From the pics above you can see that the Military does have most of the other knives beat in regards to the size of the ricasso. Some see a large ricasso as a waste of blade but they are needed for the choil so a balance must be struck there. The choil and ricasso looks much bigger on the Police4 but even with that the cutting edge on the Police4 is still longer than the entire blade on the Military. Keep in mind that this is done with maybe 1/16 inch more handle length so not much is given up to achieve that larger choil.
Here is a top down pic to show the blade grind and some of the handle thickness.
Even though the Police4 has a lot more blade than the Military and even though it has full liners vs the Military's partial liners it doesn't weigh much more. This is probably due to the thinner blade stock and generously skeletonized liners. Getting a good pic of the liners can be a challenge but this picture shows it fairly well.
Here is the Para2, Military, Police4 and K2 on a cheap scale.
That is most of it. The next post will be in hand shots and some extra poser pics.
