Replacement washers
Replacement washers
I just want replacement washers for my delica. It seems so simple. Spyderco will not send them to me. Other forums say look around this forum. Does anyone know where I can get the washers ? Or what the size they are ? Any info would be great!
- farnorthdan
Re: Replacement washers
Welcome to the forum sentinel0garek, replacement washers can be found at knife supply vendors, I know its been mentioned here a few times but I can't remember where exactly, someone should come along soon with the info.
Look on KnifeKits.com they carry many different washers and knife parts. :)
- The Deacon
Assuming the same washers are used in all the lined FRN models produced for Spyderco by G Sakai, the approximate dimensions are:
OD = 8.25 mm
ID = 4.00 mm
Thickness = .08 mm
OD = 8.25 mm
ID = 4.00 mm
Thickness = .08 mm
Hi, sentinel0garek:
Could you please private message me your name and e-mail address? I'll look into this for you.
Thanks much!
Kristi
Thanks much!
Kristi
Thank you everybody for the replies ! I will be looking into all suggestions !
Does anyone know the size of the washers for the manix 2 xl?
I took my Delica and Endura apart, and sent all the SS parts away to get cerakoted black. When I did so, I distinctly remember removing one phosphor bronze washer from each one.
I got all the parts back last year, and let them sit in a drawer because I was too lazy to do the work. I finally started doing it yesterday, and I installed both washers in the Delica by accident, one on each side of the blade. You can't see a difference, and the knife works very nicely.
So I need to get a pair of washers for my Endura. I've looked around, and can't find the right ones. One source says the proper washer is OD: 0.316, ID: .161, thickness: 0.0035.
If anyone knows a source for this washer, please let me know.
Dear CJ Levadne:
Stay safe,
Mike
Stay safe,
Mike
