Spyderco sharpmaker angle?
Hello
I bought this spyderco sharpmaker
What angle should I use on my delica ?
Trying on a opinel how can I make this razor sharp
Delica 4 Zome , Lava Silver
- farnorthdan
Re: Spyderco sharpmaker angle?
I usually do the 30 degree with a few lite passes on the 40 for a micro.
Is the 30 sharper then the 40?farnorthdan wrote:I usually do the 30 degree with a few lite passes on the 40 for a micro.
Sharpness is not dependent on the angle.
30 degrees should be fine for both of those knives.
I sharpen the knifes only on the corners of the sharper right ? So 20 on the black 20 white
30 may be too steep to hit the edge.
I have a dull Swiss Excelsior what's the best method to make it razor sharp ? First 30 on the grey stone then 30 on the white?
You can use corners or flats. I typically only use flats for most knives, and use the corners only on serrated blades, hawkbill, etc.
Brown to white is the progression you want. You can make a knife razor sharp with either set of stones once you're skilled, but its easier with the whites.
If they are really blunt, you will need the diamond stones or else you will be there for days on the browns
http://www.serendipity.li/more/myth_of_apollo.htm" target="_blank
Current collection: ZDP-189 Delica 4, S110V PM2, St. Nick's 4v Para 3, H1 sheepsfoot Manbug, Kapara, VG-10 Dragonfly, ATS-55 Serrated Delica, ZDP-189 MT04 (not broken yet) + Other non spydercos.
let us know how it turns out.
This thing is so sharp now I can shave me with it.
Cutted right in my finger
