Ha, if you do it first, we can profit from anything that goes wrong :) The bevel looks pretty minimal on Wouter's sample, so maybe it would fill in OK between the layers, or maybe you could just continue the bevel onto the new slab. I'm sure you've already thought of all this. I guess theoretically, you could just cover up all the screws except the pivot, and if you needed to get to them, you could drill out over them at the time -- a little tricky but possible, I think, or rip off the add on. I'm thinking about at some time maybe getting a Dremel router attachment or a small linoleum cutter and using a roundover bit to contour G-10 scales.Evil D wrote:I figured adding to the factory G10 would be easier than making new scales from scratch. I guess epoxy alone is enough hold them together? I'm not sure about the factory peel ply texture, there's gonna be a bevel from the factory scale between the two layers, that might look crappy. I guess I'll have to look into it. I also have an idea about reshaping the handle like a Yojimbo 2 handle.
Manix2 Backlock!
Re: Manix2 Backlock!
Note to self: Less is more.
That's true, I don't plan on adding much to each side so the additions will probably contour out immediately from the factory scales so they could very well just follow the factory scale bevels. The more I think about it the more I wanna do it. I need to get one and see what I can do.DougC-3 wrote:Ha, if you do it first, we can profit from anything that goes wrong :) The bevel looks pretty minimal on Wouter's sample, so maybe it would fill in OK between the layers, or maybe you could just continue the bevel onto the new slab. I'm sure you've already thought of all this. I guess theoretically, you could just cover up all the screws except the pivot, and if you needed to get to them, you could drill out over them at the time -- a little tricky but possible, I think, or rip off the add on. I'm thinking about at some time maybe getting a Dremel router attachment or a small linoleum cutter and using a roundover bit to contour G-10 scales.Evil D wrote:I figured adding to the factory G10 would be easier than making new scales from scratch. I guess epoxy alone is enough hold them together? I'm not sure about the factory peel ply texture, there's gonna be a bevel from the factory scale between the two layers, that might look crappy. I guess I'll have to look into it. I also have an idea about reshaping the handle like a Yojimbo 2 handle.
- Scottie3000
Forgive me if I missed it, but are these made with the same process (EDM?) and/or of the same quality as the Native 5 as far as lock fit and function? Spyderco has always made a good back lock, but the Native 5 is the benchmark in the industry as far as I'm concerned. I assume another Golden made backlock would be on par.
- bearfacedkiller
I too hope that they are manufacturing this lock with the same tight tolerances as the Native5. I don't know if that has been confirmed or not.
- Larry_Mott
Judging by the brief encounter i had with it in Amsterdam it felt well on par with the Native IMO.Scottie3000 wrote:Forgive me if I missed it, but are these made with the same process (EDM?) and/or of the same quality as the Native 5 as far as lock fit and function? Spyderco has always made a good back lock, but the Native 5 is the benchmark in the industry as far as I'm concerned. I assume another Golden made backlock would be on par.
These are in stock at at least 2 dealers I can see.
In stock at knifeworks.com
Mine shipped yesterday from KnifeCenter, should be delivered by Friday.
Someone take theirs apart and send me pics :D
Hey Killer,bearfacedkiller wrote:I too hope that they are manufacturing this lock with the same tight tolerances as the Native5. I don't know if that has been confirmed or not.
Yes, it's the same. Now that we've got it down, and it works well, no sense in changing. Haven't found any glitches in this method".
- bearfacedkiller
Outstanding!!!
I own 4 Native5s and they all lockup bank vault tight. No matter how hard I try I cannot get the Native5 lock to budge or wiggle at all.
- Scottie3000
That sealed it for me. Inbound!
sal wrote:Hey Killer,bearfacedkiller wrote:I too hope that they are manufacturing this lock with the same tight tolerances as the Native5. I don't know if that has been confirmed or not.
- GoldenSpydie
Sounds great! My original backlock Manixes (C95 and Mini) are very solid, and I'm sure this new model will continue the tradition.
- dreadpirate
And what is it we are trying to fix with the current Manix 2??
Hi Pirate,
We're not trying to fix anything.....it's not broken. Some of our customers have asked for the Manix pattern in a back-lock, so we're responding to their requests. You don't think that you are going to like or agree with everything we do, do you? We serve a large market with a variety of tastes and preferences.
Sal can correct me if I'm wrong, but I don't think the backlock is going to replace the CBBL model. The backlock is just another offering for those who do not prefer the CBBL (strange as that is). Besides, the original Manix was a backlock.dreadpirate wrote:And what is it we are trying to fix with the current Manix 2??
And this is why I am a Spyderco fanatic. Sal listens to us.sal wrote:Hi Pirate,
I am always amazed every year how many customer suggestions actually make it into production. What other company does that? None that I know of.
This Manix 2 back lock is going to be epic. It appears to be rugged and strong.
Doc Dan wrote:And this is why I am a Spyderco fanatic. Sal listens to us.sal wrote:Hi Pirate,
Absolutely can not wait! Saturday for me!!!
I think the CBBL M2 will still be my favorite, but I know I'll love the linerless Back Lock. I just like to try all the interesting kinds I can. Each one has it's own good points and you never know until you try one out. Who knows? -- we may get a linerless G-10 CBBL or BBL Manix at some point.
I just got mine and I absolutely love it. In my humble opinion it's better than the CBBL manix in every way :)
It warrants an IMMEDIATE cruwear sprint run.
