Ha good response!Spydergirl88 wrote:Do you like bad@ss knives?
Has a pretty classic Kurosawa film to back it up, as well.
jazz does have a pretty good point.
You will be so unconciously used to carrying your regular assorted Delica, when you go to pick up the Yojimbo 2, or slide it into your pocket, you will notice a difference right away.
Not an issue for many users daily carrying a Manix 2, or Millie, or Gayle Bradley... but going from every day with a lightweight Delica to the Yojimbo 2 is a bit of a hefty jump. Not that the Yojimbo 2 is absurdly heavy, but just fair warning before you get one and end up scratching your head.
Also, that blade really flies out of there with some authority, both open and closed! (I don't recall if I've seen you mention if you've owned or used a Compression-lock knife...?)
If none of that is much concern for you, then go for it! It's a current classic in the Spyderco line-up, and for good reason. You definitely wouldn't be alone contemplating using one for regular non-SD tasks! (There's a lot of great threads about it, too)
Ergos and use are very straight forward. That tip is right there, low, and feels like an extension of your hand, and goes wherever you point your thumb!
I really enjoy mine, and use it often. Brilliant design and execution!
I'd still be highly interested in one with a tough tool steel. :)
