No, I reprofiled to 30° with a 40°MBMattM68 wrote:Factory edge?
I've found trying to totally remove flat spots (the shiny spots) along the edge can take time, depending on the extent of the damage...ShawnKirkpatrick wrote:Thanks for all the advice guys. It is possible that maybe I didn't remove all the burr. I thought I was getting good at removing them, guess I need to focus more on that. But I thought it seemed like stout cardboard, and maybe I shouldn't have cut against the flutes the whole time. I spent about 5-10 minutes on the SM and got it slicing newspaper again but when shining a light on the edge I can still see some shiny spots. Any other advise guys?
I assume you did not cut off the old damaged edge as a first step of sharpening? This makes a huge difference in edge retention in my experience. It is easy to build a seemingly perfect edge by sharpening the old damaged edge, but it will show damage not long after you put it to work. This happens because the underlying steel is still fatigued. I have seen this time and again, especially on my wife's kitchen knives. They see some rough use, and I often have to resharpen rolled edges. If I am lazy and do not cut off the old edge before I sharpen them, they will show damage much quicker than if I do.ShawnKirkpatrick wrote:Thanks for all the advice guys. It is possible that maybe I didn't remove all the burr. I thought I was getting good at removing them, guess I need to focus more on that. But I thought it seemed like stout cardboard, and maybe I shouldn't have cut against the flutes the whole time. I spent about 5-10 minutes on the SM and got it slicing newspaper again but when shining a light on the edge I can still see some shiny spots. Any other advise guys?
Users browsing this forum: dan31, GarageBoy, Google [Bot], Granoo Fink, RogerRozen, soc_monki and 44 guests
