Sal, any hope for a Cruwear Native 5 in dark gray G10?
- RadioactiveSpyder
Hi there Sal,
With your recent (and a bit unexpected!) smash hit CPM-Cruwear Paramilitary 2 sprint run, can we Native 5 lovers hope to see this steel with the same dark gray G10 as the PM2 sometime soon? I hope you procured enough of that color G10, it's just great!
Thanks so much,
Radioactive :)
Thanks so much,
Radioactive :)
- Liquid Cobra
Re: Sal, any hope for a Cruwear Native 5 in dark gray G10?
Seconded.
@liquid_cobra
@liquid_cobra
Instant classic.
just curious, why a relatively tougher, lower wear resistance steel for a smaller knife? If a carbon steel is desired something like 10V or M4 would seem to make more sense.
Unless it's more just to have the whole Golden lineup in cruwear?
- bearfacedkiller
I would like to see a grey LW Native in Cruwear.
I'd be up for one of those!bearfacedkiller wrote:I would like to see a grey LW Native in Cruwear.
G10 Cru-Wear Native5? Please and thank-you.
I'm not sure if size is always the deciding factor of how hard we use our blades. I have beat the crap out of my xhp native. The shape and ergos of that design do beg to be beaten on.Skywalker wrote:just curious, why a relatively tougher, lower wear resistance steel for a smaller knife? If a carbon steel is desired something like 10V or M4 would seem to make more sense.
I'm in. I don't have the steel or the model. Ok, I did break down and order the Cruwear PM2 this morning, but technically....
- Mark
This sounds fantastic ~ Another vote here
Count me in. I think the Native 5 is awesome knife and this steel would pair nicely.
Yes but N5 LW for me
- Larry_Mott
Native Cruwear/G10 - Yay!
Native Cruwear/FRN - Meh!
Here is an interesting comparison.
http://zknives.com/knives/steels/steelg ... hrn=1&gm=0
- RadioactiveSpyder
I hear you, but either way I know that any N5 Cruwear blade of mine would end up in a G10 frame regardless...Larry_Mott wrote:Native Cruwear/G10 - Yay!
My feelings exactly...I'd still get it but G10 definitely my preference.Larry_Mott wrote:Native Cruwear/G10 - Yay!
Cruwear has better wear resistance than S30V, I do believe (it's supposed to be better than 3V in wear resistance, less toughness). 3V wear resistance is similar to S30V.
So you actually own both?Larry_Mott wrote:Native Cruwear/G10 - Yay!
Well, for CPM 3V vs CPM CruWear, Crucible's datasheets agree with you that 3V should be a bit tougher and CruWear should have a bit more wear resistance.Cujobob wrote:Skywalker wrote:just curious, why a relatively tougher, lower wear resistance steel for a smaller knife? If a carbon steel is desired something like 10V or M4 would seem to make more sense.
CPM CruWear - http://www.crucible.com/PDFs/DataSheets ... 202010.pdf
CPM 3V - http://www.crucible.com/PDFs/DataSheets ... 202015.pdf
And Crucible also puts S30V as slightly ahead of CPM 3V for wear resistance.
CPM S30V - http://www.crucible.com/PDFs/DataSheets ... 202010.pdf
And I know those sheets are all relative with no wear resistance units (though they're present for toughness) and they get used for marketing as much as anything else, but CruWear is in ballpark S30V wear resistance and is significantly tougher, seems to be their story.
This thread on bf and this thread on bf and this more convoluted thread here all seem to suggest that for end-user testing, cru-wear may be slightly behind S30V in wear resistance, but not by much, and close enough that experimental error is probably enough to cover any sort of difference.
So I guess it's more of a step sideways than I had initially realized, into more toughness and maybe ease of sharpening being traded for S35VN's stainlessness, without too much of a change in wear resistance.
I had assumed it was further down the more toughness/less wear resistance curve than it really was; it makes a bit more sense now (though I would still prefer M4, haha).
What I get for assuming, I guess. :rolleyes:
(I know the Native5 uses S35VN, not S30V, but you mentioned S30V in particular so I figured I'd just roll with that since the consensus seems to be that they're basically indistinguishable to users.)
Thanks for bringing all of the information in for reference. I think Cruwear, because of its high attainable hardness, will really depend on the heat treat for what sort of edge retention you'll get. Custom makers seem to do well with it whereas Spyderco may be on the more conservative side in a production setting.
