I just wanted to write and compliment Sal and Spyderco for the SP<img src="spyder.gif" width=15 height=15 align=middle border=0>T. I have the micata model and find it to be the perfect everyday wear. It is extremely light and can be worn discretely under anything. Around my neck or in my hand, it's at home at work in the city, as well as at play in the mountains. It's amazing that <img src="spyder.gif" width=15 height=15 align=middle border=0>s first intro to the neck knife market put them right at the top. Again... I tip my hat to you.
Thanks,
Gary
See SPT run!
Prior to wearing my SP<img src="spyder.gif" width=15 height=15 align=middle border=0>T I had worn a CRKT Bearclaw. Although the Bearclaw is quite functional (and costs less), the difference between the two is tremendous. You always knew the Bearclaw was around your neck due to its weight and shape. The SP<img src="spyder.gif" width=15 height=15 align=middle border=0>T is sooo light you do not know it is there. I adjusted the length so that it lays between my pecks, which is both comfortable and keeps it from showing through thin jerseys. I presume that the cord covered chain is quite strong (just an assumption on my part). The chain did pinch my neck and chest hair, but once shortened shorter than the covering cord... it was great. Aside from shape and weight, the SP<img src="spyder.gif" width=15 height=15 align=middle border=0>T workmanship is not second to any <img src="spyder.gif" width=15 height=15 align=middle border=0> I own or have seen. My suggestion.... Go for it!
Gary
PS: I'd post a picture of me wearing it, but will hold off hoping that Simona will post one... <img src="wink.gif" width=15 height=15 align=middle border=0>
Edited by - Gary on 1/16/2003 11:42:32 AM
Gary
I'm currently wearing my collector's Micarta serrated SPOT. I've been wearing it since I got it (and replaced a PE Cricket in a Sastre sheath). It's quite comfortable to wear, but I think my biggest issue is the ball-chain. My skin can be irritated quite easily by non-precious metals/stainless-steel/titanium.
I would love to find a good source of full stainless-steel ball-chain, or perhaps one that's made of something a bit more expensive (like silver).
Edited by - nomaded on 1/17/2003 4:46:28 PM
- Knife Knut
