What he said^SpyderNut wrote:Unlined, PE, and FFG would do the trick for me. I'd also like it to be full screw-together construction instead of pinned. The white Goddard Sprint is a favorite design of mine. Would love to see this happen!
I just found a picture on the net, from this website, that shows you have a Goddard Jr. in green polished micarta. Very nice. That is the sort of thing I had in mind with the G10.The Deacon wrote:With Spyderco, you never know. The last Goddard Jr. Sprint sold slowly. but I'm fairly sure the combo edge blade had more than a little to do with that. I think both it and the Baby Goddard Sprint would have done a lot better if they were plain edge, so maybe Spyderco will try again. I'd love to see them in Micarta, but polished G-10 would also work for me, as long as they're kept unlined.
Have three of the original Goddard Jrs, PE, PS, and SE, plus the white SprintDoc Dan wrote:I just found a picture on the net, from this website, that shows you have a Goddard Jr. in green polished micarta. Very nice. That is the sort of thing I had in mind with the G10.The Deacon wrote:With Spyderco, you never know. The last Goddard Jr. Sprint sold slowly. but I'm fairly sure the combo edge blade had more than a little to do with that. I think both it and the Baby Goddard Sprint would have done a lot better if they were plain edge, so maybe Spyderco will try again. I'd love to see them in Micarta, but polished G-10 would also work for me, as long as they're kept unlined.
I would not mind FRN if it had the bi-directional texturing.
Screwed-up would be a total deal breaker for me.SpyderNut wrote:Unlined, PE, and FFG would do the trick for me. I'd also like it to be full screw-together construction instead of pinned. The white Goddard Sprint is a favorite design of mine. Would love to see this happen!
I understand. I would be quite willing to acquiesce pinned construction if we could at least keep it FFG and unlined G-10 or Micarta scales.The Deacon wrote:Screwed-up would be a total deal breaker for me.SpyderNut wrote:Unlined, PE, and FFG would do the trick for me. I'd also like it to be full screw-together construction instead of pinned. The white Goddard Sprint is a favorite design of mine. Would love to see this happen!
What's wrong with you Michael? original grind looks much betterSpyderNut wrote:I understand. I would be quite willing to acquiesce pinned construction if we could at least keep it FFG and unlined G-10 or Micarta scales.The Deacon wrote:Screwed-up would be a total deal breaker for me.SpyderNut wrote:Unlined, PE, and FFG would do the trick for me. I'd also like it to be full screw-together construction instead of pinned. The white Goddard Sprint is a favorite design of mine. Would love to see this happen!
I agree, Roman. HG looks a lot better than FFG on this design, but I'd love to see them CQI it for FFG.bh49 wrote:What's wrong with you Michael? original grind looks much betterSpyderNut wrote:I understand. I would be quite willing to acquiesce pinned construction if we could at least keep it FFG and unlined G-10 or Micarta scales.The Deacon wrote:Screwed-up would be a total deal breaker for me.SpyderNut wrote:Unlined, PE, and FFG would do the trick for me. I'd also like it to be full screw-together construction instead of pinned. The white Goddard Sprint is a favorite design of mine. Would love to see this happen!![]()
I never heard complains about cutting abilities either.One change I would love to see, in case of Goddrd Jr. blade stock 2 mm instead of 3 mm.
OK. 2.5 mm will be better for me than 3mm. So we can have compromise.What about grind? Can we have original? Change is not always CQI. Our president proved thisSpyderNut wrote:I agree, Roman. HG looks a lot better than FFG on this design, but I'd love to see them CQI it for FFG.bh49 wrote:What's wrong with you Michael? original grind looks much betterSpyderNut wrote:I understand. I would be quite willing to acquiesce pinned construction if we could at least keep it FFG and unlined G-10 or Micarta scales.The Deacon wrote:Screwed-up would be a total deal breaker for me.SpyderNut wrote:Unlined, PE, and FFG would do the trick for me. I'd also like it to be full screw-together construction instead of pinned. The white Goddard Sprint is a favorite design of mine. Would love to see this happen!![]()
Can we maybe shoot for 2.5 mm?
Bravo and well said, sir! LOLbh49 wrote:OK. 2.5 mm will be better for me than 3mm. So we can have compromise.What about grind? Can we have original? Change is not always CQI. Our president proved thisSpyderNut wrote:I agree, Roman. HG looks a lot better than FFG on this design, but I'd love to see them CQI it for FFG.bh49 wrote:What's wrong with you Michael? original grind looks much betterSpyderNut wrote:I understand. I would be quite willing to acquiesce pinned construction if we could at least keep it FFG and unlined G-10 or Micarta scales.The Deacon wrote:Screwed-up would be a total deal breaker for me.SpyderNut wrote:Unlined, PE, and FFG would do the trick for me. I'd also like it to be full screw-together construction instead of pinned. The white Goddard Sprint is a favorite design of mine. Would love to see this happen!![]()
The Deacon wrote:The thinner the better, as far as I'm concerned. However, once you go below 2.5mm FFG makes more sense than hollow, at least to me.
I would love to see it back in FRN and I think the full size Goddard would (also-) be perfect for an H1/FRN version.clovisc wrote:Would love to see a H1 and\or FRN incarnation.
