play ???
joebe
play ???
Postby joebe » Thu Jan 09, 2003 1:00 am
when you have the blade locked in the open position and you press it against a hard object (cutting board) is it normal to have a little play in the blade ? it's minnimal but there is justed a bit before it stops. i would guess this is normal after the knife has broken in ?
<img src="sad.gif" width=15 height=15 align=middle border=0> <img src="spyder.gif" width=15 height=15 align=middle border=0> <img src="spyder.gif" width=15 height=15 align=middle border=0> <img src="wink.gif" width=15 height=15 align=middle border=0>
Sword and Shield
Postby Sword and Shield » Thu Jan 09, 2003 12:30 pm
How much is "a little"? A mm or so is normal, as the lockbar is designed with a little leeway to compensate for wear.
Never underestimate the impossible.
john
Postby john » Thu Jan 09, 2003 12:58 pm
What model Spydie are you taking about?
Pahl
Spydie.com
joebe
Postby joebe » Thu Jan 09, 2003 1:01 pm
it's only maybe a mm or so, really not much just seemed strange....
FRN Endura.
yog
Postby yog » Thu Jan 09, 2003 1:10 pm
If it's a lockback knife then a mm or so of play is normal. This is a feature of ALL lockbacks and is caused by the built in tolerance needed for the locking bar to clear the notch in the blade tang for when it is disengaged.
Walk softly, carry a big stick.
Users browsing this forum: bbturbodad, blades&wrenches, elena86, JD Spydo, koenigsegg, Theldraskien and 37 guests
