Page 1 of 1
Looking for factory replacement pocket clip
Posted: Fri Apr 08, 2016 9:33 pm
by harronek
Could someone direct to where I can buy some genuine factory stainless pocket clips for the Delica model .
I own a few Delica's and the stainless pocket clip on my Titanium is so much better than the black painted ones found on the standard FRN models .
The black paint begins to wear the nano second you start to use the knife .
I'd like to replace the black ones with the stainless version on all my Delica's .
I've tried searching , but all I get are after market clips , I want original .
I looked on Spyderc's site , but again struck out , maybe I'm not looking in the right place .
Any help would be appreciated .
Ken
Re: Looking for replacement pocket clip
Posted: Fri Apr 08, 2016 9:36 pm
by farnorthdan
Shoot Ken I'd just ring the SFO and ask for a few, I know I've heard of others getting them. They probably charge for them but it cant be much.
Posted: Fri Apr 08, 2016 9:43 pm
by harronek
farnorthdan wrote:Shoot Ken I'd just ring the SFO and ask for a few, I know I've heard of others getting them. They probably charge for them but it cant be much.
I live in Australia and long distance calls are both expensive and inconvenient due to time differences etc .
Do they have an EMail address for parts and service that I could maybe try ?
Here is a few pics to explain why I want the new clips .
Both of these clips have done a similar amount of work .
The clip on my GB1 is a different finish and I suspect is powdercoated or baked on because it has lasted very well for the amount of work it has done , but even it is now showing signs of wear .
Ken
Re: Looking for factory replacement pocket clip
Posted: Fri Apr 08, 2016 10:03 pm
by farnorthdan
Sure they do, not sure exactly what it is, I'm sure one of the gang will jump in with it or maybe go to the home page and look for contact info..
Posted: Fri Apr 08, 2016 10:35 pm
by jabba359
Go here:
http://www.spyderco.com/contact/
Under "Retail Sales," select the drop down for "I need a new clip for my Spyderco knife" and it'll take you to an email contact page.
For some reason, Spyderco doesn't put the clips on their site to buy, but they are available. I believe I paid $7 or so for the last one I ordered.
Alternatively, I had a black clip that looked just as bad as the OP's on my blue Delica 3. I used some automotive paint remover and now it is a mildly shiny matte grey, which looks a ton better and is cheaper than buying new clips. Pic below.
Posted: Fri Apr 08, 2016 11:44 pm
by harronek
Thanks for the replies .
To tell you the truth I never thought about removing the paint and polishing the original clip .
It might be a cool little project .
I think I will still send Spyderco a message on the link you posted and see if they will sell me 3 stainless ones and post them to Australia .
Thanks again for the help .
Ken
Posted: Sat Apr 09, 2016 4:41 pm
by harronek
Five minutes work with some 1200 grit sandpaper and this is the result .
I won't bother Spyderco with any messages , this has solved my problem easily , quickly and with zero cost .
Thanks for the suggestion jabba359 .
Ken
Posted: Sat Apr 09, 2016 5:53 pm
by farnorthdan
Right on Ken, that looks great.
Posted: Sat Apr 09, 2016 6:26 pm
by EvanB.
I just removed the paint from my Endura using polishing compound and a Dremel tool. Took all of 5 minutes. Looks great against the grey scales.
Posted: Sun Apr 10, 2016 6:55 am
by Johnnie1801
Nail varnish remover and a bit of steel wool removes the paint in seconds :)
Posted: Sun Apr 10, 2016 10:16 am
by jabba359
harronek wrote:Five minutes work with some 1200 grit sandpaper and this is the result .
Ken
Always glad to help! :D
