Perrin PPT Scales White-ish Tint
Has anyone else had the issue with their Perrin PPT scales having a white-ish fade going on with them? I have only carried this knife twice and it seems to be a lot lighter than when I got it. Is there something I can do to combat this? I did try wiping the scales down with a damp towl but it went right back. Thanks in advance for any responses.
- Liquid Cobra
Re: Perrin PPT Scales White-ish Tint
I posted this very same question months back but I never got an answer. I figured I was the only one to experience the problem.MechEng_5 wrote:Has anyone else had the issue with their Perrin PPT scales having a white-ish fade going on with them? I have only carried this knife twice and it seems to be a lot lighter than when I got it. Is there something I can do to combat this? I did try wiping the scales down with a damp towl but it went right back. Thanks in advance for any responses.
A few weeks ago it was bugging me again so I started thinking about how to fix it again. I guess the scales were getting dried out or something. I decided to apply some nano-oil to the scales themselves. Just rubbed it on with my hands and then wiped them clean with a towel. They went back to being nice and black but didn't feel oily, the scales must have absorbed some of the oil.
So far they're still black. If it starts to get white again I'll just repeat the process. Hope this helps.
@liquid_cobra
@liquid_cobra
Thanks your Liquid Cobra this is helpful. I searched for other threads like this but didn't see any. I will try some nano-oil.Liquid Cobra wrote:I posted this very same question months back but I never got an answer. I figured I was the only one to experience the problem.MechEng_5 wrote:Has anyone else had the issue with their Perrin PPT scales having a white-ish fade going on with them? I have only carried this knife twice and it seems to be a lot lighter than when I got it. Is there something I can do to combat this? I did try wiping the scales down with a damp towl but it went right back. Thanks in advance for any responses.
- jabba359
G-10 can go white or lose color intensity if it's dried out a little too much. I use a bit of mineral oil to bring my G-10 back to full color.
Wax lasts a bit longer than oil, but both work well. Something food safe like mineral oil would probably be the best idea if using oil.
Any oil should do, it should be most likely to occur on more shaped handles like these. I do some bone and wood carving and also like to try stuff in micarta and G10, have seen similar stuff on carvings I did in G10. Seems like the glassfiber 'sticking out' on the edges where it get's cut by carving.
- jabba359
Yeah, my LionSpy also gets a little white in the "valleys" of the texturing. The material turning white seems to be more prone on the textured pieces as Joris pointed out.
- ChrisinHove
Same as automobile plastics, I guess.
- RadioactiveSpyder
Use mineral oil not Nano-oil! Mineral oil is non-toxic and food safe, Nano-oil certainly is not. Not to mention how vastly cheaper mineral oil is...
I work with G10 fairly often and always finish the scales with a thorough water rinse, soak in mineral oil, rinse again and blot dry. It's incredible how much it brings the color out!
- Liquid Cobra
This is a good point, I never thought of that. I guess since the PPT is self defence blade food prep never came to mind.RadioactiveSpyder wrote:Use mineral oil not Nano-oil! Mineral oil is non-toxic and food safe, Nano-oil certainly is not. Not to mention how vastly cheaper mineral oil is...
I'll have to add mineral oil to my knife kit. Thanks radioactive!
@liquid_cobra
@liquid_cobra
- RadioactiveSpyder
Sure thing LC, I'm here to help :)
