Hi Ruarch, I do all the actual fillet work with the Phil Wilson. The Pacific Salt does things like steaking and head and tail removal. The serrated edge excels at some of the rough work and saves the edge on my fillet knife.Ruarch wrote:Do you find the serrations make it more difficult to clean them? Love the Salts! Keep the pics coming.
Haha, I kind of hope you never get your wish. Australia isn't the only place where those big boys swim in the ocean. I see them from time to time on my kayak, sometimes MILES from the nearest rivermouth. Some of those guys go 6 meters down here.elena86 wrote:I'd like to see a picture of a SE Pac Salt near an aussie Salty.Both have deadly teeth.But your shot has glamour indeed Lance.
Hi Surfingringo, so the H1 SE holds up to sawing through bones pretty well? And does well with filleting? I will have to try it out.Surfingringo wrote:Hi Ruarch, I do all the actual fillet work with the Phil Wilson. The Pacific Salt does things like steaking and head and tail removal. The serrated edge excels at some of the rough work and saves the edge on my fillet knife.Ruarch wrote:Do you find the serrations make it more difficult to clean them? Love the Salts! Keep the pics coming.
I have actually filleted a few mackerel with the serrated salt and while certainly not the best tool for the job, as long as it is kept very sharp it works surprisingly well.
Hi SEF, never messed with octopus but I prefer a plain edge for cutting squid. It is so soft and squishy that a se tends to pull it too much.SpyderEdgeForever wrote:Would the Pacific Salt be a good one to clean an octopus or squid with or no?
Hi Ruarch, remember that i said the se salt was capable of filleting, not that it was good at it.Ruarch wrote:Hi Surfingringo, so the H1 SE holds up to sawing through bones pretty well? And does well with filleting? I will have to try it out.Surfingringo wrote:Hi Ruarch, I do all the actual fillet work with the Phil Wilson. The Pacific Salt does things like steaking and head and tail removal. The serrated edge excels at some of the rough work and saves the edge on my fillet knife.Ruarch wrote:Do you find the serrations make it more difficult to clean them? Love the Salts! Keep the pics coming.
The reason I ask is because my (cheap not-quite-walmart-version) fillet knives dull pretty fast and I am guessing it is because I cut right to the bone and make sure I go through the meat and into the bone and draw across the ribcage. It could just be that they are cheap knives and would dull on paper. I guess I just grew up with cheap fillet knives and have just now thought about getting a decent one.
And remember, when cleaning fish, a coarse low grit edge is your friend. I freehand my fillet knives on a 600 grit Lanky diamond stone. The finished edge will still shave facial hair but has a TON of bite so requires much less force when cutting through skin and scale and will "grip" the media instead of sliding across it. This results in much less downward force and much better edge retention.Surfingringo wrote:Hi Ruarch, remember that i said the se salt was capable of filleting, not that it was good at it.Ruarch wrote:Hi Surfingringo, so the H1 SE holds up to sawing through bones pretty well? And does well with filleting? I will have to try it out.Surfingringo wrote:Hi Ruarch, I do all the actual fillet work with the Phil Wilson. The Pacific Salt does things like steaking and head and tail removal. The serrated edge excels at some of the rough work and saves the edge on my fillet knife.Ruarch wrote:Do you find the serrations make it more difficult to clean them? Love the Salts! Keep the pics coming.
The reason I ask is because my (cheap not-quite-walmart-version) fillet knives dull pretty fast and I am guessing it is because I cut right to the bone and make sure I go through the meat and into the bone and draw across the ribcage. It could just be that they are cheap knives and would dull on paper. I guess I just grew up with cheap fillet knives and have just now thought about getting a decent one.Until Spyderco comes out with the Phil Wilson collaboration fillet knife I would just get a $20 Dexter Russel. A gazillion commercial fishermen can't be that wrong.
sal wrote:Knife afi's are pretty far out, steel junky's more so, but "edge junky's" are just nuts.![]()
Thank you sir! I have never bothered to sharpen a cheap knife, just got a new one. I will have to use a low grit and try that.Surfingringo wrote:And remember, when cleaning fish, a coarse low grit edge is your friend. I freehand my fillet knives on a 600 grit Lanky diamond stone. The finished edge will still shave facial hair but has a TON of bite so requires much less force when cutting through skin and scale and will "grip" the media instead of sliding across it. This results in much less downward force and much better edge retention.Surfingringo wrote:Hi Ruarch, remember that i said the se salt was capable of filleting, not that it was good at it.Ruarch wrote:Hi Surfingringo, so the H1 SE holds up to sawing through bones pretty well? And does well with filleting? I will have to try it out.Surfingringo wrote:Hi Ruarch, I do all the actual fillet work with the Phil Wilson. The Pacific Salt does things like steaking and head and tail removal. The serrated edge excels at some of the rough work and saves the edge on my fillet knife.Ruarch wrote:Do you find the serrations make it more difficult to clean them? Love the Salts! Keep the pics coming.
edit:Apparently I quoted my own post rather than editing it. Oh well.
I have heard Sal mention that they are working on something. Not sure if it is near future or far over the rainbow. I believe there was even a prototype at Blade this year? Someone please correct me if i'm wrong about that.bearfacedkiller wrote:I passed on the Southfork (so far) and am very interested in the Sprig. I would be EXTREMELY interested in a Phil Wilson fillet knife. Do you know something Lance? Please tell me this is a real possibility. :-)
Hi Arty, last I heard they were discussing doing the fillet knife in cpm154. I don't remember if I read that here or heard it at the Blade show. Either way I would be really happy to find out it were true because it is a great steel! I chose cpm154 for my custom fillet knife that Phil made me.arty wrote:I think that a Spyderco fillet knife in a good steel would sell. By good steel, I mean something like S35V or VG10, preferably S35V.
Other companies have fishing knives in VG10 and are selling them (Fallkniven). Bark River and Warther have fillet knives in S35V, and I have been using one of my Warthers in the kitchen for some time.
If Spyderco puts out a new fishing knife, it will sell, for sure. I'll likely get one, assuming the specs are right.
Users browsing this forum: Bing [Bot], Deadboxhero, Google [Bot], jacala, LanM, Majestic-12 [Bot], Notsurewhy, tbdoc4kids, TenGrainBread and 47 guests
