How to fix Military blade centering issues: https://youtu.be/wU797Pkmq1Q" onclick="window.open(this.href);return false;
Its worked on a couple of mine.
The Cruwear Millie was a 1200 piece sprint so prices are still very reasonable due to the large number made.
CPM CRUWEAR vs. CTS-XHP Military - which one should I buy first?
Re: CPM CRUWEAR vs. CTS-XHP Military - which one should I buy first?
Thanks for the tip - I tried it and it helped a little bit :) On this knife when I tighten the pivot screw fully the blade is perfectly centred so I'm not sure what's going on...Bile Bob wrote:How to fix Military blade centering issues: https://youtu.be/wU797Pkmq1Q" onclick="window.open(this.href);return false;
As I said I'm not worried about having a perfectly centred blade on this knife, but I appreciate the thought!
Bruno
Go with XHP, though you'd be hard pressed to notice a difference in edge retention between it and S30V. What would probably be most immediately apparently would be easier sharpening on the really high grit abrasives because of the much lower vanadium, and for that reason alone I'd go XHP.glbpro wrote:Which of these two do you think I should get first? I do not currently own any other knives in these steels. I do own a normal S30V military, and I'd like to try out a new steel. Knife will be a user!
- HarleyXJGuy
This, all day everyday.D-Roc wrote:Military in any sprint is worth it. Buy both.
Oh and Pam had a great posterior.
