For example Spyderco has used the CATRA ranking for edge retention, however as shown by Verhoeven's work, the high silica content of the paper in the CATRA machine produces a rounded over, very worn apex, however is this really how kitchen knives dull? Here is an interesting article which says it isn't.
- http://www2.eng.cam.ac.uk/~mpfs/papers/ ... -63538.pdf" onclick="window.open(this.href);return false;
What they find is that in actual commercial use :
is that blunting doesn't happen by slow wear, the apex's are not rounded over as in the CATRA trials, they are deformed. They way they propose to rank steels for edge retention is to look at the resistance to deformation. This is the same way that Roman Landes ranked steels in his work - apex stability.Professional knives were tested in well-controlled real field
conditions in three different meat-processing units: two meatprocessing
plants (bovine and poultry respectively) and a
butchery.
It might be interesting for Spyderco to at least, if possible, make a couple of test mules for their kitchen knives and use some steels which have a very high resistance to deformation at the apex vs a high wear resistance. This may not only give higher ease of sharpening and durability it might even provide higher edge retention. At the very least it is worth a look.
I have a number of the Spyderco kitchen knives and they excel in ergonomics, cutting ability and general performance. It would be pretty interesting to see Spyderco explore the application of some of the current research in the commercial industry to maximize the performance of their kitchen knives.
Given the relationship with Carpenter this should be easily possible, maybe even to the limit of getting a custom stainless steel made for kitchen knives and doing what would essentially be the equivalent of introducing the next S30V.
