No Full Knife Disassembly for Para 2 Back Spacers...
- BOOMER52
Back spacers for the Paramilitary 2 which requires no full disassembly of the knife to install. The lanyard pipe opening in these G10 back spacers snap over the lanyard pipe due to the flex in the spacers lower tang. The Para2's stainless barrel spacer fits into the back spacers hardware hole and you just rotate the spacer into position for securing with the hardware screws. Only the two screws and barrel spacer need removal for installation of this type of back spacer.
- Liquid Cobra
Re: No Full Knife Disassembly for Para 2 Back Spacers...
Besides the fact that it looks cool, why would you add a back spacer to a knife that has open construction? Does it improve the knife in some way for your uses?
@liquid_cobra
@liquid_cobra
On some it indeed improves the grip, this one looks like it will as the raised parts, jimping? will give your palm traction. In some situations closing it in as much as possible keeps dirt out longer even if it traps it in once it gets there. Also some people like the added weight.
- 3rdGenRigger
Looks can definitely play a part. I wouldn't put this on my 204P PM2 but I feel it suits this knife well.
All Glory To The Hypno-Toad
---> Branden
---> Branden
- BOOMER52
The back spacer was the result of a request from a customer having no ability to disassemble his Paramilitary 2... but wanting the aesthetics and utility a back spacer provided. Lanyard pipes can make disassembly difficult for even skilled individuals.
To what degree of aesthetics and utility a back spacer provides... I leave that up to the individual. I'm just trying to fill a niche.
Point taken sir...BOOMER52 wrote: To what degree of aesthetics and utility a back spacer provides... I leave that up to the individual. I'm just trying to fill a niche.
And hats off to you for providing what looks to be a good product that is unlike anything I've seen out there...America at its best! :D
- bearfacedkiller
Is this an advertisement?
Looks very nice.
Looks very nice.
- kennethsime
I think it's cool that you're coming up with a solution for your customers, making modding more accessible. That said, I wouldn't personally add this to my PM2.
Looks like a cool solution.
- BOOMER52
Some different G10 colors... gray... forest green... & black...
- 3rdGenRigger
Any pictures of how close the forest green is to the green G10 on the KW 204P PM2? If it's close enough I might just have to try to snag one of these.
---> Branden
---> Branden
Nice workaround!
- Capt'n Boatsalot
Luckily, the grey, royal blue, and forest green in the previous post are mine and should arrive tomorrow. The green one is slated for my KW 204P model. I'll post some photos as soon as I can. I'm hopeful that the greens are a close match as well!3rdGenRigger wrote:Any pictures of how close the forest green is to the green G10 on the KW 204P PM2? If it's close enough I might just have to try to snag one of these.
Wow, those are really awesome. Great idea.
Great knife, thanks for sharing your good items.
I like your posts. and the knife design is so great.
- Capt'n Boatsalot
Mine arrived today... And they are awesome. Installation was straightforward and painless. They fit well. The tolerance is good (e.g. blocks are a consistent height). I didn't realize that they also extended off the butt by 1/16". Not a problem at all, I just hadn't noticed it when ordering. Obviously they add some non-negligable weight and change the balance slightly. I did have to adjust the stop pin screws slightly on both knives to get the blade back to how I like it.
I like the feel of the backspacer in my hand. Kind of like the Techno. No surprise which of my updated PM2s is modeled after that wonderful knife.
I think the Forest Green matches well with the Knifeworks 204P model, but I will let you all decide for yourselves.
Unmodified knives with the new backspacers:
How do I go about getting one of these?
Sharp knife / hairless arm.
sign me up.. id like to snag one. where/how?
are these cnc milled? laser cut? 3D printed? handmade? I want to 3d print a custom backspacer and I like this idea.
:spyder: Turtles can have knives too, right? :spyder:
Aus-8 Delica 1 ATS-55 Endura UK Penknife
Positron Mamba Blurple PM2
