Spyderco Endeavor
Spyderco Endeavor
I might be dreaming :o but I seen this mentioned in a thread on another forum.
Thoughts on the rumored Spyderco Endeavor??? I did a search and didn't see a recent topic on it. Has it been discussed here much?
David
Blue Titanium/Jigged Bone: Endura Damascus, Delica Damascus (finally!)
Foliage G10: Endura FFG, Delica FFG
OD Green G10: Worker Sprint
Black FRN: Endura FFG, Delica FFG, Dragonfly FFG, Matriarch 2, Lil Matriarch, Centofante 3, Salt 1 PE
Grey FRN: Endura FFG, Delica FFG
Purple FRN: Endura FFG, Delica FFG
Green FRN: Delica FFG
Denim Blue FRN: Lil Matriarch PE (Thanks McL!)
- Stuart Ackerman
Re: Spyderco Endeavor
Emerson do an Endeavor...
Are you assuming a collaboration?
I believe you're referring to the "NASA Bushcraft" with S90V steel and an FFG. Sal stated that the proto will be photographed by Wouter at the Amsterdam meet in March.
Yes thisABX2011 wrote:I believe you're referring to the "NASA Bushcraft" with S90V steel and an FFG. Sal stated that the proto will be photographed by Wouter at the Amsterdam meet in March.
David
Essentially Chris Claycomb's Bushcraft handle (but in solid Carbon Fiber) and a full flat utility shaped blade (designed by Chris) in CPM-S90V. Not made for Bushcrafting, but for general utility, but with a Bushcraft handle that can be used all day every day without any "hot spots" developing.
- Johnnie1801
This sounds like a very nice knife :Dsal wrote:Essentially Chris Claycomb's Bushcraft handle (but in solid Carbon Fiber) and a full flat utility shaped blade (designed by Chris) in CPM-S90V. Not made for Bushcrafting, but for general utility, but with a Bushcraft handle that can be used all day every day without any "hot spots" developing.
Are you going with a leather or boltaron sheath?
Jon
Jon
- DutchBlades
Now I have yet another reason for wanting March to be here sooner :D
A tiger has claws.
A wolf has teeth.
An eagle has talons.
We, have Spyderco.
Grails: Abalone Mini Mariner, Ti ATR, WTC, Ti Lum Tanto
A wolf has teeth.
We, have Spyderco.
Thanks sal for your answer.
Anxiously awaiting pics!
David
The thinking at this time is Boltaron.Johnnie1801 wrote:This sounds like a very nice knife :Dsal wrote:Essentially Chris Claycomb's Bushcraft handle (but in solid Carbon Fiber) and a full flat utility shaped blade (designed by Chris) in CPM-S90V. Not made for Bushcrafting, but for general utility, but with a Bushcraft handle that can be used all day every day without any "hot spots" developing.
Good choice IMO!
- SpyderNut
Are there any prototype pics of this yet?
- Johnnie1801
I've seen some of Chris's work on other forums and from what I'm reading about this project it sounds like a home run from Spyderco :D
Jon
Jon
Sounds brilliant! :Dsal wrote:Essentially Chris Claycomb's Bushcraft handle (but in solid Carbon Fiber) and a full flat utility shaped blade (designed by Chris) in CPM-S90V. Not made for Bushcrafting, but for general utility, but with a Bushcraft handle that can be used all day every day without any "hot spots" developing.
