Maintenance tips?
DJD
Maintenance tips?
Postby DJD » Sat Oct 04, 2014 7:47 pm
What's the preferred product to lube Spydercos?
Thanks.
Cujobob
Re: Maintenance tips?
Postby Cujobob » Sat Oct 04, 2014 8:00 pm
I like Nano-Oil for pivots.
LC Kid
Postby LC Kid » Sat Oct 04, 2014 8:11 pm
Hi DJD!
My first response lube is the Nano Oil as well, for metal liner folders.
For no liners, or for FRN I don't use any lube.
SpyderNut
Postby SpyderNut » Sat Oct 04, 2014 8:27 pm
I prefer FP-10 lube for my knives. Not only does it work well on pivots, etc., but it also has a pleasant smell. :) It works well on firearms too.
Trout Hound
Postby Trout Hound » Sat Oct 04, 2014 8:55 pm
I would think that some type of dry lube, such as Rem-Dri, applied parsimoniously with a cotton swab, might work well. It won't pick up lint, dirt, etc. the way that oil will.
A sharp knife is a pleasure to carry. Five or six sharp knives are an even greater pleasure.
Trout Hound
DJD
Postby DJD » Sat Oct 04, 2014 9:00 pm
As Trout Hound mentioned....have the oils mentioned ever seem to collect lint or dust?? Just curious if anyone has experienced that and gone to a dry lube.
SpyderNut
Postby SpyderNut » Sat Oct 04, 2014 9:37 pm
DJD wrote:As Trout Hound mentioned....have the oils mentioned ever seem to collect lint or dust?? Just curious if anyone has experienced that and gone to a dry lube.
No, I've not noticed that, but I think the key is to use any type of lube very sparingly.
farnorthdan
Postby farnorthdan » Sat Oct 04, 2014 9:43 pm
Nano oil works well, I also use a graphite based lube called Dri-slide bike aid, I started using this on my throttle cables some time ago and have found it works great for knives also.
paladin
Postby paladin » Sat Oct 04, 2014 10:11 pm
Just Use It...seriously use it / open it a lot...
My EDC is a Spderco gray Calypso Jr. ...
It has never seen a drop of oil...
I wash it with soap & warm water then dry with a blow dryer as needed...
Still opens, closes, & locks up as good as the day I bought it...
Not trying to be a wise guy here, but oil & lubes can invite & retain grit / gunk if over-used...just use it as is out of the box...
Nano oil is a good choice if you must use a liquid lube...but go very easy as SpyderNut advised...
Frog Lube if you want a dry lube...good luck!
DJD
Postby DJD » Sat Oct 04, 2014 11:18 pm
Thanks for the replies!
HarleyXJGuy
Postby HarleyXJGuy » Sat Oct 04, 2014 11:23 pm
Just having bought a new Spydie I was wondering the same thing.
So far I have not put any oil on mine because of all the dust and dirt where I am. Plus I figure it will help break in what for me seems like a very stiff knife.
Postby Bolster » Sat Oct 04, 2014 11:41 pm
What if you use your knife for food prep? What lubricant then?
Mineral oil? Wax? Vegetable oil? Bacon grease?
paladin
Postby paladin » Sun Oct 05, 2014 6:34 am
Bolster wrote:What if you use your knife for food prep? What lubricant then?
Mineral oil, of those you have listed...
The other two will go rancid...
FrogLube is paste that you melt on with a hair dryer, it then "seasons" the steel (think: like how you prep a cast iron skillet), & then dries on it leaving behind a slicker surface...
Plus it's food safe, I've had good luck with it
Trout Hound
Postby Trout Hound » Sun Oct 05, 2014 7:30 am
+1 on mineral oil for food prep. I use it to oil my carbon Mora for that reason.
Trout Hound
MacLaren
Postby MacLaren » Sun Oct 05, 2014 7:34 am
I most all times use M-Pro7.
Sometimes, I'll use Weapon Shield w/ its needle applicator. Its from the same inventor as FP10. And, it smells good too :)
WireEdge Roger
Postby WireEdge Roger » Sun Oct 05, 2014 7:47 am
FP-10 here as well, must be a Hoosier thing? :D I love the smell.
I've used it for years! Good on garage door rollers and patio door tracks too.
PMBohol
Postby PMBohol » Sun Oct 05, 2014 8:03 am
Another vote for MPro7 LPX. Also, Breakfree CLP is good stuff too.
Delica 4 FFG
Paramilitary 2 DLC Digicam
Brad Southard flipper (missing in action)
Sharpmaker
Gayle Bradley 2.
Gayle Bradley Air
SpyderNut
Postby SpyderNut » Sun Oct 05, 2014 9:02 am
WireEdge Roger wrote:FP-10 here as well, must be a Hoosier thing? :D I love the smell.
Haha! It must be a Hoosier thing is right. ;) I've been using FP-10 on my guns/knives for the past 16-18 years. Like you said, it works well in many different applications around the house too. Plus, the smell is very pleasant. :)
swedishgrunt
Postby swedishgrunt » Sun Oct 05, 2014 9:35 am
i tried many sorts of american oil products and never liked any of them.
so i use the same lube as i use to my fishing reels.
cals universal reel & star drag grease on some knives.
but for most i use TG´s rocket fuel red label.
good stuff.
Postby Evil D » Sun Oct 05, 2014 9:39 am
Keep them clean. That's the most important thing. You don't need to take them apart to clean them either, just work the pivot in soapy water then work the pivot under running water, blow out with compressed air and drop in a few dops of pretty much any kind of lubricant you have access to. Lots of people over complicate this topic, and the lubes being used are so overkill for such a simple mechanism. While some lubes will no doubt be silkier than others, you can drop some common 3-In-1 household oil and get a smooth action. Dry lubes have their pros and cons just as wet lubes do. I've found that White Lightning make both types and they all work very well for knife pivots and can easily be found at Walmart for cheap and a bottle will last you years.
Users browsing this forum: cabfrank, Doc Dan, Freediver, Google [Bot], Hobnob, Majestic-12 [Bot], Mushroom, Stuart Ackerman, Wright.88 and 50 guests
