Thoughts on the gray Delica 4 FFG
Hi Folks.
I finally did it. I bought a new Delica 4 FFG to replace the old model Delica. The old model did not have liners and was not full flat ground. It also did not fit my XL hand very well. I had not bothered to replace it because I love the Caly 3 so much I did not see the point (no pun intended. Well, maybe not). But, I had a need for a light weight knife with a blade longer than 2.25" and less than 3" that did not cost an arm and a leg in case it was lost. I also wanted a good knife with good steel and good craftsmanship. In my opinion, Spyderco is now building the best knives they have ever built, based on quality. They rival, and even excel, more costly production and custom offerings by rivals.
I found what I was looking for in the Delica 4 FFG, in spades! The knife arrived very sharp. It would not pass my toilet paper test, but almost. It is very sharp. The fit and finish are excellent, as expected. There are no hotspots on the knife at all. I took off the clip and this knife is so comfortable in my XL hand I wondered why I ever bought that Mini-Griptilian years ago. O yeah, then I remembered, the Delica 4 was not available. When I put my hand naturally on the handle, the end is just barely inside my hand. That is, my pinky finger extends minimally past the handle. Also, the finger groove point hits my middle finger right in the center. However, if I squish my fingers together and tighten my grip, these go away and rather than dig into my finger, the high point of the finger groove pulls my hand deeper into the grip. Pretty amazing.
The knife is almost the same size as my Caly 3 but the handle is slightly longer. The Caly 3 actually fits my hand better because of the finger choil. But, the Delica is much lighter and feels great in the hand.
Since I got it, I have been looking for things to cut. I cut tape. I cut open boxes. I scraped stickers off of bottles. I cut bags and clam shell plastic, aggravating, developed to make a saint cuss, packages. It did all of this with aplomb. I also cut apples. I did a side to side comparison if cutting between Spyderco Chaparral, Caly 3, Cold Steel Mini Recon 1, Benchmade Mini Griptilian, Benchmade Mini Landslide, and this knife. Not all knives will cut apples well. I may post photos later. The Delica 4 FFG was nearly, not quite, but nearly on par with the Caly 3.
There is no, zero, play in the blade. The knife will flex a little side to side but not much, and some may think that is play. It is not. It is the thin stock and scales flexing under pressure, at least on my example. There is zero up and down blade play. There is, however, just slight bit of up movement when the knife is pressed with pressure onto a cutting board. None of my other, many, Spyderco lock backs have this play. It does not affect the performance, it is just something unique to this design.
For what I needed, this knife is really nice and met all of my needs. Now my wife wants one in purple! It is a good thing Spyderco does not offer second mortgages, or they would own my house.
Doc
Doc
Ha! Better Bourbon is very, very expensive here as it is not halal. But, if you want to ship me some... :)
I love how flat the knife is and how it simply does not show in your pocket, so I am with you on that. It feels great in my hand, even though my wife says I have King Kong hands.
I did not notice your location, I apologize. Better doesn't always mean more expensive (in the US at least). Elmer T Lee single barrel can be found here for $30 a bottle (similar to beam) and is just outstanding. It's hard to find in stock, of course, but I just think about it like the PM2 of bourbons. Unfortunately, unlike PM2s, you run out of bourbon periodically. I have no idea what sending one to you would involve, but I'd do my best for a fellow D4 lover.
I too love the delica 4. It was my first spyderco, and still my favorite for edc in town. It looks innocent so sheeple don't freak out, but it is still 3" of razor sharp steel. Mine is my "pocket scalpel" and excels at mundane everyday use. It looks innocent, but I'd have no qualms using it for self defense either. That sharp 3" blade will cut to the bone! I think it's one of spyderco's most iconic offerings, and hope they offer it forever!
DLC Paramilitary 2 S30V, Manix 2 S30V hollow ground, Delica 4 stainless with custom engraving, green frn delica 4 ffg, blue frn delica 4 ffg, orange frn endura 4 ffg, Gayle Bradley
Been using the same blade at work all morning love it I forget I have it on me. My lock up is tight also and no play. I remember back in the day when I first started getting into knives (2008 is back in the day for me) people would always tell me to get a delica and I resisted for years. A knock off buck, two SAKs homemade shanks and a blackhawk I just now see the value I missed.
Own: C81GPBN2 x 2
Wanted: FB30GP, FB37GGRP, C180GP, C10FPBN x 2, C11FPBN & FB35PBK and a C204MF most of all!
- _centurio_
- bearfacedkiller
Love mine. Thin blade, ss liners, lightweight, ffg and four way clip. Just terrific. Three of my coworkers carry ffg delica 4s and they all seem to really like them.
How about you folks posting pictures?
I am really loving this knife. I used it to prep meat for the cooker. I washed it first, of course.
Quite enjoying the gray Endura I procured as well :) Like you Doc, Workmanship/quality is superb :D . Spyderco and their makers are doing a very good job :) I have to believe the Endura and Delica are made by the same maker.
Hope You're enjoying the SuperBlue steel, sweet edges when you want and holds them well :D
Charlie
- bearfacedkiller
Very nice! I love that Superblue! Mine is VG-10. But I am a BIG fan of carbon steel blades on knives. You are very fortunate.bearfacedkiller wrote:
Mine is VG-10. I would have preferred Superblue on the Delica 4, but I did not find one. I love carbon steel.dbcad wrote:Quite enjoying the gray Endura I procured as well :) Like you Doc, Workmanship/quality is superb :D . Spyderco and their makers are doing a very good job :) I have to believe the Endura and Delica are made by the same maker.
Nice knives. I also have a Pingo. It is my favorite Slipit.
Thanks for the offer. The bottle would get broken and I am not certain about the taxes. But, when I come home again, I will stock up!tvenuto wrote:That exact knife is what started my Spydie obsession. It's a phenomenal little workhorse that disappears in the pocket until needed, and it gets pocket time despite the many other "higher end" spydies I now have. Great choice!
Now we just need to talk about getting you some better bourbon.
one of my favorite quotes regarding booze comes from MMA fighter Forrest Griffin, "beer is an acquired taste, you might as well acquire a taste for a cheap one". Same could apply to bourbon I suppose. Bourbon is on the list of booze I can't even smell now because of throwing it up too many times in college. More for the rest of you to enjoy I suppose...
