Review of the Spyderco Stretch sprint run in Super Blue
GoldenSpydie
Postby GoldenSpydie » Sun Jul 20, 2014 2:34 pm
Hi everybody,
I took this series of pictures a while ago as a review of the SB Stretch, but I never got around to doing a write-up.
I figured that I should do write this review now, while several dealers still have them in stock. :)
In case you somehow don't know about the Stretch or about Super Blue steel, here is the description per Spyderco:
____________
"The Stretch is a purpose-designed folding hunting knife that is also ideal for a broad range of everyday chores.
This unique limited-edition version combines the proven design and ergonomics of this popular knife with the exceptional cutting performance of Super Blue steel. Produced by Hitachi Metals Ltd. of Japan, Aogami Super Blue steel combines the same high quality iron sand used in legendary Japanese swords with high-tech alloys to create a steel capable of extreme sharpness and edge retention. The blade of the Stretch Super Blue features a Super Blue core sandwiched between layers of 420J1 stainless steel.
Full flat ground for exceptional edge geometry, this knife is available in limited quantities and is sure to be one of the most coveted Stretch variants ever produced."
____________
Per Eric (or was it Sal?) Glesser, "the Stretch is a pretty tough Hombre."
____________
I decided to set out to test the limits of this special Spyder.
Here is what it looked like when new:
The knife came sharp, but the edge was much improved by stropping.
The handle uses a blue/gray color of FRN with the usual bi-directional texturing. The back spacer is also FRN.
The Stretch uses a back lock (0.115 inch thickness) to hold the blade open. It has a Boye dent to prevent accidental closing.
The clip is the standard "spoon" style and has a black coating. The knife has holes for 4 clip mounting options. It comes tip up on the right.
____________
Blade measurements:
Overall blade length: 3.53 inches
Sharpened length: 3.29 inches
Width at plunge line: 1.15 inches
Thickness of the spine at the plunge line: 0.12 inches
Thickness behind the edge: 0.028 inches
Other knife measurements:
Handle thickness: 0.44 inches
Widest point when folded: 1.63 inches
Length of handle: 4.57 inches
Total weight: ~3.25 ounces
____________
Before the test began, I sharpened it on a 203 Sharpmaker, going all the way to UF rods. I then stropped the blade on green compound. It was easily my sharpest knife at the time.
First: Bushcraft-type wood work. I batoned some small piece of Russian olive, an invasive tree that grows in CO. The Stretch handled this with no problems whatsoever.
(And yes, I know, batoning is bad for folding knives, but yes, I did it anyway. :rolleyes :)
Next, I tried it out on smaller wood--making feather sticks and carving points. As would be expected, the FFG excelled at this.
Abusive tip-tests are next. The Stretch has a fairly thin tip, but these tests proved that it is not fragile. I decided to drill a hole in a piece of pine. I stabbed it into the stump, and twisted until the tip had carved a hole about an inch deep and 3/4 of an inch wide.
(This would be useful for making a bow-drill for fire starting. Wrong type of wood, but that doesn't matter for this test.)
max 10 pics/post; cont. below
GoldenSpydie
^ cont. from above ^
That was not a problem for the SB Stretch at all! What about metal? :eek: I stuck it about 1/4 of an inch into an old rain gutter. This dulled the tip significantly, but everything stayed intact and it penetrated the metal easily.
(The knife was not designed for this in the least sense of the term, but it proves that the tip is quite strong.)
And now, it's off to the kitchen! At this point, it could have used a sharpening. But I decided to wait in order to see how the edge performed on food after being dulled somewhat by wood and metal.
(And yes, I washed it first.)
It easily sliced the vegtables, but the raw chicken proved to be a challenge for the dull blade. However, it was able to eventually complete the task. No doubt had it been sharp, it would have easily sliced the meat. Here is the SB Stretch with the dinner that if cut up.
____________
Well, that concludes my testing. It did more than I thought it was capable of, and even if stabbing gutters is not one of your EDC tasks, I am sure that this Sprint Run blade will please you. :)
Here are a few more shots:
Thanks for reading, and I will do a review on the Manix 2 Cruwear soon.
http://www.spyderco.com/forums/showthre ... post961771
twinboysdad
Postby twinboysdad » Sun Jul 20, 2014 2:37 pm
I only got the SB E4 but it is my favorite knife I own. SB is amazing
Liquid Cobra
Postby Liquid Cobra » Sun Jul 20, 2014 2:39 pm
Great review! Really great to see the knife put through it's paces. It would be nice to hear how sharpening went after your test. Maybe some shots of what it looked like after all those beatings.
Most recently acquired: Paramilitary 2 Tanto, YoJUMBO, Swayback, Siren, DLC Yojimbo 2, Native Chief, Shaman S90V, Para 3 LW, Ikuchi, UKPK, Smock, SUBVERT, Amalgam, Para 3 CTS-XHP, Kapara, Paramilitary 2 M390
@liquid_cobra
MacLaren
Postby MacLaren » Sun Jul 20, 2014 2:43 pm
I had the chance to get a Caly 3.5 SB a while back, but backed out. It was pricey. The Stretch is prolly the best way to go for me.
Spydernation #0031
PayneTrain
Postby PayneTrain » Sun Jul 20, 2014 4:20 pm
Hah sounds like a fun day there. Nice photo review, thanks for sharing!
Holland
Postby Holland » Sun Jul 20, 2014 4:34 pm
Awesome thread! Thanks for sharing. I bought this knife a few days ago and I'm having a very hard time warming up to the ergo. I think I'll give it another week and then if it hasn't made it's way I to my rotation it may be part of my upcoming sale thread :rolleyes:
Junction | Gayle Bradley 2 | Dragonfly 2 | Leatherman
GoldenSpydie
Postby GoldenSpydie » Sun Jul 20, 2014 4:51 pm
Thanks guys!
Liquid Cobra wrote:Great review! Really great to see the knife put through it's paces. It would be nice to hear how sharpening went after your test. Maybe some shots of what it looked like after all those beatings.
Good idea. I will update with sharpening info and "after" pics soon.
Jazz
Postby Jazz » Sun Jul 20, 2014 5:37 pm
Nice review. Thanks for sharing.
I beat the heck out of a Delica FFG a while back, including poking through cans of various thicknesses. I was quite impressed (it was VG10).
- best wishes, Jazz.
bornagainprimative
Postby bornagainprimative » Mon Jul 21, 2014 3:51 am
I like the look of the stretch with its belly and choil
Own: C81GPBN2 x 2
Wanted: FB30GP, FB37GGRP, C180GP, C10FPBN x 2, C11FPBN & FB35PBK and a C204MF most of all!
Johnnie1801
Postby Johnnie1801 » Mon Jul 21, 2014 8:19 am
Just a few pics of my SB Stretch. I have been EDC'ing this knife just about every day since I got it. It is really a fantastic slicing knife and pretty easy to maintain. The knife is actually smaller than a PM2 yet the blade and cutting edge is longer. The patina on the knife has developed naturally from cutting apples and other fruits, in the beginning it was fun to watch it developing, now it has dulled down but I still like it, kind of quirky. On the minus side, I do find the ergo's a little uncomfortable. I have large hands and when holding the knife in a saber grip my fingers are squeezed into the handle also the choil could be a bit deeper (mute point as this has been addressed in Sal's new prototype). When new the paint on the clip seemed to be better than on my Delica however recently it has started to come off on the edges. I don't think there will ever be a knife that is 100% perfect but I really enjoy using this knife and I would recommend it to anyone looking for a light EDC blade.
Jon
phillipsted
Postby phillipsted » Mon Jul 21, 2014 12:54 pm
I'm really starting to enjoy the laminated SB steel. It is easy to sharpen and gets a really refined edge with just a little work.
Great pics, GoldenSpydie and Johnnie!
TedP
Jazz
Postby Jazz » Mon Jul 21, 2014 7:35 pm
That top down view of the blade looks so cool!
kaysa
Postby kaysa » Tue Jul 22, 2014 8:17 am
Thanks for a good and informative review, I am still hesitate to get non-stainless steel,
I heard patina can help prevent rusting of steels, but I wonder how it work,
how to "apply" patina to knives, and how about the hidden parts?
like inside the pivots, and the liners...
Johnnie1801
Postby Johnnie1801 » Tue Jul 22, 2014 9:27 am
kaysa wrote:Thanks for a good and informative review, I am still hesitate to get non-stainless steel,
The blades on the Manbug, Ladybug, Dragonfly, Delica, Endura and Stretch are laminated. They have Super Blue steel on the inside and 420J on the outside. The hidden parts are therefore protected by 420J. The dark areas on my first and last pic (along the edge and on the spine) are the only areas where the SB is exposed. The patina will develop naturally when you cut food (e.g fruit or meat) however some people like to force a patina by leaving the blade in lemon juice or something. Each patina is unique and it can be fun to see how it develops. If you live in a very humid area then rust might be a problem but if you look after your knife, wipe it after use and oil it occasionally then I think it will be ok.
If you haven't got a blade in SB yet then all I can say is try one, you won't regret it. I just wish I had got the Caly 3 in full SB, it's a fantastic steel.
Jon
GoldenSpydie
Postby GoldenSpydie » Tue Jul 22, 2014 10:06 am
Johnnie1801 wrote:The blades on the Manbug, Ladybug, Dragonfly, Delica, Endura and Stretch are laminated. They have Super Blue steel on the inside and 420J on the outside. The hidden parts are therefore protected by 420J. The dark areas on my first and last pic (along the edge and on the spine) are the only areas where the SB is exposed. The patina will develop naturally when you cut food (e.g fruit or meat) however some people like to force a patina by leaving the blade in lemon juice or something. Each patina is unique and it can be fun to see how it develops. If you live in a very humid area then rust might be a problem but if you look after your knife, wipe it after use and oil it occasionally then I think it will be ok.
^ Kaysa, what Johnnie said is correct. ^
The only Super Blue part on the Stretch is the approx. 1/4 inch on each side at the edge. All of the hardware is stainless.
____________
Here is a picture with several other Spyders for size comparison:
And here are two pictures of the knife as it is today:
hawkeye180
Postby hawkeye180 » Tue Jul 22, 2014 11:57 pm
I want a Super Blue Stretch so bad, but I keep holding off for some reason.
klug932000
Postby klug932000 » Wed Jul 23, 2014 7:08 am
Are there any other models that will be released in the bear future?
some of my work (nothing for sale on there) Facebook.com/454products
GoldenSpydie
Postby GoldenSpydie » Wed Jul 23, 2014 8:04 am
klug932000 wrote:Are there any other models that will be released in the bear future?
Do you mean with Super Blue? I don't know of any upcoming sprints with Super Blue, but anything can happen.
If you just are talking about new products in general, sure, there are tons!
klug932000
Postby klug932000 » Wed Jul 23, 2014 8:27 pm
I meant sb, I know the endura delica dragon fly stretch and mule have been done, just wondering if anymore are in the pipe line.
Users browsing this forum: Google [Bot], Humbbaby, kobold, VipeX and 44 guests
