I'm afraid that I'm gonna loose it! Anybody else?
Not my mind! (LOL.) My Manix 2 (G-10) ! :p Seriously : I was climbing in and out of rental trucks while helping some friends move yesterday, so I was worried that my knife would fall out of my pocket. I found myself periodically (and neurotically) checking that it was still there by placing my hand upon my pocket. I know that the clip is fairly secure while attached to the pocket, but the knife could still become caught upon something such as a seatbelt and fall out - unbeknownst to me. :eek: I'm thinking about attaching a lanyard to my knife and securing the bitter end to my belt loop during strenuous activity such has hiking and scrambling.
Anyone else here suffer from OCD regarding loosening a knife? :)
Found myself having similar concerns about losing my sprint runs so you're not alone! :) I got the needle and thread out and sewed little strips inside all my trouser pockets. I just pocket clip my Spydies to these bits of material instead which keeps the clip hidden and protected from snags about an inch below the lip of the pocket, if that makes any sense?
On the topic of losing a knife......I've also had the same concerns. The lanyard idea is one that I've also thought of and would be easy to implement. I was thinking of a simple loop of paracord through the lanyard hole and then a loop behind and pull through behind a belt loop so that you could pull the knife out of your pocket and use it near your body with the knife being hooked to a belt loop and then if you need to use it further away it would be very quick and easy to pull it through the slip loop and disentangle it from your belt loop.
This would provide some extra reassurance during strenuous activity and if the knife did fall out of your pocket it would be easy to feel it hitting the outside of your leg still attached to your belt loop - rather than being left behind in some field.
- Surfingringo
- The Deacon
I avoid having to worry about that by carrying my knives loose in my back pocket. Been doing it that way pretty much every day for over sixty years now and have yet to lose one. I can't see any advantage to clipped carry, certainly none that outweighs the potential for snagging the clip on something and damaging or losing the knife, damaging my clothing, and/or damaging the item upon which the clip snagged.
- Officer Gigglez
- Location: Originally out of Arizona, currently live in Missouri.
I don't have any concerns for my knives, as the clips are impressive in strength. My flashlight however, well, the clip isn't very good and catches on things a lot, so I am constantly making sure it is still there.
-Tenacious, Combo edge
-Tasman Salt, PE
-Persistence Blue, PE
-Pacific Salt, Black, PE
-Delica 4, Emerson Grey
-DiAlex Junior
-Byrd SS Crossbill, PE
-Endura 4 Emerson Grey
-Byrd Meadowlark 2 FRN, PE
-Resilience
-Tasman Salt, PE
-DiAlex Junior
-Resilience
- Officer Gigglez
I would say it depends on the purpose for what method you use to carry them.The Deacon wrote:I avoid having to worry about that by carrying my knives loose in my back pocket. Been doing it that way pretty much every day for over sixty years now and have yet to lose one. I can't see any advantage to clipped carry, certainly none that outweighs the potential for snagging the clip on something and damaging or losing the knife, damaging my clothing, and/or damaging the item upon which the clip snagged.
-Tasman Salt, PE
-DiAlex Junior
-Resilience
-Tasman Salt, PE
-DiAlex Junior
-Resilience
Quite often, especially my cell phone if I elevate my legs by way of an ottoman or recliner. It really depends on the pockets in the shorts or jeans that I happen to be wearing at the time. I need to buy a few more pairs of shorts with cargo pockets that fasten.Surfingringo wrote:Or you could just not use the clip and put the thing in your pocket. When's the last time something fell out of your front pocket?
I concur except for those of us who wear scrubs or other clothing with loose open pockets ( or non-existent ).The Deacon wrote:I avoid having to worry about that by carrying my knives loose in my back pocket. Been doing it that way pretty much every day for over sixty years now and have yet to lose one. I can't see any advantage to clipped carry, certainly none that outweighs the potential for snagging the clip on something and damaging or losing the knife, damaging my clothing, and/or damaging the item upon which the clip snagged.
Clips can also it may be easier to index/find/retrieve the knife in certain situations.
Thankful that the clips are removable all the same. :)
What is truth? Pontius Pilate
- chuck_roxas45
I thought the saying was "use it or lose it".
I frequently still use my old Buck belt leather pouch / sheath and rotate my medium and large folders in and out. Protects the knives, keeps lint and crud out of the pivot. Keeps my pocket free for other stuff. My coin pocket gets the small knives. Hard to break old habits. :D
Focus is just distraction from distraction, so I take my moderation in moderation.
I used to worry but I take a couple precautions that help ease the fear. 1) make sure the clip clips tight. Over time especially if clipped to thick material often, the clips can become weak and need tightened. All you do is simply remove the clip and bend it a little and put it back on. 2) I never use lanyards on any EDC knife. They can easily snag and pull your knife out of your pocket and you won't even notice. 3) I have an "EDC bowl" that I dump all my daily carry items in and my knife is always either in my pocket or in that bowl unless it gets rotated out with another knife and then it gets put back in the box and stacked with my other knives.
Pretty simple routine that's always helped me keep track. I used to use loss an excuse for not paying a lot for a knife but I realized I have things that are almost worthless that I've managed to keep track of for years that are easily replaced so having something of value should get more attention and less chance of loss.
- Surfingringo
Good point. I usually carry iwb so it's more obvious if the knife moves but, like you, I also have the habit of checking my knife often. I do the same thing when I'm hunting. I habitually check the safety on my gun. It may be a bit OCD but I haven't shot anyone yet. I say keep checking!HorserloverFat wrote:Quite often, especially my cell phone if I elevate my legs by way of an ottoman or recliner. It really depends on the pockets in the shorts or jeans that I happen to be wearing at the time. I need to buy a few more pairs of shorts with cargo pockets that fasten.
