Page 2 of 3
Posted: Fri Jul 18, 2014 10:24 am
by asmith001
Surfingringo wrote:I know some folks like it, but that "kindergarten scissors" tip...
LOL
Nice mod, Lance. It looks great. After owning a PM2 and a Millie, the Salts, Delicas, Enduras, etc. look a little weird to me at the tip. This would change their overall look for sure.
I cleaned/reconditioned/sharpened/polished a Tasman Salt for a friend recently. His tip was slightly bent up towards the spine. I just ground/sanded the bent tip off, and did the same thing you did here until I got the spine to meet the edge again, creating a nice pointy tip again. Afterwards, you really couldn't tell I did anything to it.
Posted: Tue Jul 22, 2014 10:24 pm
by delphidoc
Nice job, Surfingringo!
Couple of questions:
1) On the 60 grit sandpaper, did you rub the spine to-and-fro or side-to-side?
2) Did the metal mushroom out along the edges of the spine or just grind down clean and skinny?
Thanks for the info.
Larry
Posted: Wed Jul 23, 2014 6:10 pm
by Surfingringo
delphidoc wrote:Nice job, Surfingringo!
Larry
I rubbed tip to heel as I think it's much easier to keep everything vertical and even that way. No "mushrooming", but the edges were a tad sharp after the sanding so I hit em a couple of passes on the 180 just to knock off any burr.
Posted: Wed Jul 23, 2014 7:26 pm
by opusxpn
H1 should be offered in stone washed finish, it seems to scratch easy why not give it the stone washed look from factory
Posted: Wed Jul 23, 2014 10:56 pm
by 3rdGenRigger
opusxpn wrote:H1 should be offered in stone washed finish, it seems to scratch easy why not give it the stone washed look from factory
With titanium handles..."Premium Salt" if you will. I'd still like the option for FRN on some or all (I like the FRN Salt Dragonfly), but I'd buy a titanium stonewashed Tasman SE before a FRN version (Which I do plan to buy at some point as is incidentally).
Posted: Thu Jul 24, 2014 12:16 am
by captnvegtble
Surfingringo wrote:I rubbed tip to heel as I think it's much easier to keep everything vertical and even that way. No "mushrooming", but the edges were a tad sharp after the sanding so I hit em a couple of passes on the 180 just to knock off any burr.
Can I ask what specific type sand paper you used? Was it a metal vs. multipurpose vs. wood sandpaper?
Posted: Thu Jul 24, 2014 4:20 am
by bornagainprimative
I might try this with my delica
Posted: Thu Jul 24, 2014 4:51 am
by Surfingringo
captnvegtble wrote:Can I ask what specific type sand paper you used? Was it a metal vs. multipurpose vs. wood sandpaper?
I used the 3m paper that is pictured in the op. It doesn't matter though. Any low grit paper would be fine.
Posted: Thu Jul 24, 2014 6:16 am
by Mjc1973
That looks great. I have often thought my PM2 would look great with a radiused spine but first I am going to remove the nasty scratches that my work sharp left on my delica. (I don't like my work sharp anymore)
Posted: Thu Jul 24, 2014 8:01 am
by captnvegtble
Surfingringo wrote:I used the 3m paper that is pictured in the op. It doesn't matter though. Any low grit paper would be fine.
OK. I saw it was 3M, but I couldn't tell whether it was a metal specific sand paper... wasn't sure if it mattered.
Posted: Thu Aug 14, 2014 5:22 pm
by sir_mike
Has anyone done this to a Salt 1? If so, please post pics of the mod.
I have a Salt 1 and found some 80 grit Aluminum oxide sand paper that I was going to try this on but the hump looks a little more pronounced on the Salt 1 as it is a shorter knife.
Thx.
Posted: Thu Aug 14, 2014 5:29 pm
by Jazz
Posted: Thu Aug 14, 2014 5:36 pm
I like that whistle Jazz
Posted: Thu Aug 14, 2014 5:56 pm
by Jazz
Thanks. :) I did a thread a while back on how to make them. I used to whittle a bit with my granddaughter, but she's growing up. Here's a link. It's on page 3 and down a bit...
http://www.spyderco.com/forums/showthre ... highlight=
Posted: Thu Aug 14, 2014 6:20 pm
by sir_mike
Thanks Jazz!
What did use to take the black coating off the clip? I dont like the black clip!
Posted: Thu Aug 14, 2014 6:53 pm
by Jazz
This was a clip traded off a Rescue model that came shiny. I have just sanded clips, though. Use finer stuff, then even finer, and maybe a polish. I speeded some up with my Dremel tool. It has sanding drums. You still need to use some elbow grease. That's how I did it, but others have used paint remover or something. I'm not sure. And you're welcome for the pics. My most used knife is a Salt 1 with the normal tip. I love that tip, but I do have 2 done with a point.
Posted: Thu Aug 14, 2014 7:36 pm
by sir_mike
Jazz wrote:This was a clip traded off a Rescue model that came shiny. I have just sanded clips, though. Use finer stuff, then even finer, and maybe a polish. I speeded some up with my Dremel tool. It has sanding drums. You still need to use some elbow grease. That's how I did it, but others have used paint remover or something. I'm not sure. And you're welcome for the pics. My most used knife is a Salt 1 with the normal tip. I love that tip, but I do have 2 done with a point.
I am probably in the minority but I dont have a Dremel! LOL I just looked at the pics again and noticed that the tip looks pretty thin. Is that jusg the angle or is it real thin. I was looking referring tothe second pic but it doesnt look that thin in the first one.
Posted: Thu Aug 14, 2014 8:12 pm
by Jazz
It's not that thin. There's a lot of blade thickness almost to the tip because of the hollow grind. H1 is real tough, too. I beat the crap out of an H1 blade to see what it could take. Search my "H1 versus a shoe" thread. It's long, but full of H1 and FRN testing goodness.
Here's a link to that...
http://www.spyderco.com/forums/showthre ... sus-a-shoe
Posted: Thu Aug 14, 2014 8:54 pm
by sir_mike
That's good to know. I wish Spyderco had this size H1 blade in FFG.
Posted: Thu Aug 14, 2014 8:55 pm
thank you so much for that I'm going to try making one for my two year old daughter.
