I know you can wear out a frame lock, or liner lock. But can you wear it out the "opposite way", I.E. by pushing the frame lock over too far when disengaging it? I ask because I have a folder (albeit a cheap one), and I did just that. From repeated disengagements, the frame lock just stayed disengaged after awhile. Can this happen?
Also, it seems as if people have different opinions about flicking there knives. Is there anything done to the Domino to make it a "flicker",...obvious being a flipper it is going to get flicked open, and a lot.
Thanks.
Question on frame locks, specifically the Domino
- spyderHS08
Also with it being a spyderco and having a titanium lockbar side.....I wouldn't think you'd have anything to worry about. I have a couple striders with framelocks that are older and don't have the lockbar stabilizer (the framelocks stop) and have had no problems with them "wearing out". As long as you don't abuse it you should be okay :)
39 & counting...
Dodo!
Dodo!
