Saber Ground Stretch?
- SpyderEdgeForever
What would it be like? Anyone like the idea?
I think saber grinds are pretty under appreciated and a lot more useful than most people give them credit for.
That said, I prefer saber grinds on heavier knives (like the Endura and Manix, both of which I prefer to the FFG versions). I'm not sure if the Stretch is the right platform for a saber grind.
I'm in agreement with Blerv. The Stretch is supposed to be a high-performance cutting tool, so a saber grind would really defeat the purpose of it's design.
"The skeptic does not mean he who doubts, but he who investigates or researches, as opposed to he who asserts and thinks that he has found."
- Miguel de Unamuno
Military Black G-10 DLC, Byrd Meadowlark 2 G-10, Lil Matriarch, Pacific Salt SE yellow, Endura 4 ffg brown, Native FRN PE, Dragonfly 2 Orange, Ulize, Sharpmaker and UF rods. Also, Cold Steel Voyager XL Clip PE, Kershaw Volt II (on loan), many fixed blades, and a KP strop block.
- Miguel de Unamuno
I see no benefit in making Stretch cut any worse. Indeed, I'd much rather go towards leaner grinds than thicker. It's rather easy to apply a more obtuse microbevel to a leaner grind, should you run into problems, as compared to thinning a thick blade without a belt grinder or similar mechanical aid. Sure you can eat away steel with say xxc DMT benchstone ( I have one and have used it for the purpose), but getting aesthetic results is an other matter altogether...
- RadioactiveSpyder
- The Deacon
Zero interest in a saber ground Stretch, but I'd be ecstatic if Spyderco made a full flat ground one with a 2mm thick blade and a near zero edge grind.
- Strong-Dog
I would rather have a FFG and super-thin blade stock than anything else, ever, at least on a folding knife. I love the stretch for its cutting performance, and I would not like something that would lessen that.
"For a second, I thought I was dead, but when I heard all the noise I knew they were cops. Only cops talk that way. If they had been wiseguys, I wouldn't have heard a thing. I would've been dead."
-Henry Hill
-Henry Hill
+1 with a double on the Zero interest. I'd like to have one of my user Stretches reground thinner.The Deacon wrote:Zero interest in a saber ground Stretch, but I'd be ecstatic if Spyderco made a full flat ground one with a 2mm thick blade and a near zero edge grind.
A life is like a garden. Perfect moments can be had, but not preserved, except in memory.
-Leonard Nimoy
-Leonard Nimoy
