My smoothest Spydie has always been my first C15 Terzuola from 1990. It might be due to the synthetic washers, but the action has always been glassy and a real delight to use.
TedP
Wow. Really?JB3 wrote:Southard mos def
It sounds like you have something wrong with your Southard, I would suggest sending it back in. It could be a poor detent or maybe improper lubrication. Being a ball bearing pivot, it should be very very smooth to open. My experience with mine is completely opposite of yours... Basically it's hard for me to get it to NOT open all the way like a rocket when I break the detent for the flipper. It rockets open like it's on glass rails and then will fall easily back into the handle when I disengage the lock, it's simply wonderful. You should see what you can do to get it working well rather than just letting it collect dust.TomAiello wrote:Wow. Really?
My Southard is definitely, and by far, my least smooth Spyderco folder. I never carry the thing because the Spydie hole is harder to use than my other Spydies and the "flipper" is pathetic--I've never once been able to get the blade all the way open with it (I have to use a big exaggerated wave of my arm in time with the "flip" to make it open). There have been a couple Spydies that I've been shocked at how much they impressed me when I didn't expect it (Pingo and Des Horn come to mind immediately). The Southard is the only one that's ever been the other way, and greatly disappointed me.
Tom- yours isn't right... Mine also opens very smoothly, and completely almost 100% of the time. I'm finding it difficult to get it out of the way for others that want to rotate in...Syncharmony wrote:It sounds like you have something wrong with your Southard, I would suggest sending it back in. It could be a poor detent or maybe improper lubrication. Being a ball bearing pivot, it should be very very smooth to open. My experience with mine is completely opposite of yours... Basically it's hard for me to get it to NOT open all the way like a rocket when I break the detent for the flipper. It rockets open like it's on glass rails and then will fall easily back into the handle when I disengage the lock, it's simply wonderful. You should see what you can do to get it working well rather than just letting it collect dust.
Users browsing this forum: Bing [Bot], Kevinim82, Mushroom, RandomNick, Spydergirl88, Sumdumguy, TenGrainBread, Wartstein and 50 guests
