Just picked up a Spyderco Blackhawk . . .
At a local knife show this past weekend. What intrigued me about this knife are the G-10 handles with NO liner. I never could understand why all of the G-10 knives made by Spyderco today have liners. The G-10 handle on the Blackhawk does not flex at all, so I see no point adding the weight of a SS liner. Does anyone know why Spyderco does not make linerless G-10 knives anymore?
The important thing was that I had an onion tied to my belt, which was the style at the time. You couldn't get white onions, because of the war. The only thing you could get was those big yellow ones...
- The Deacon
Exactly G-10, CF, and Micarta just don't work well with the fine threads needed to retain small screws. Spyderco has done unlined G-10 with a wire clip, but gave up on doing it with the three screw clips back around 2000. There's also the issue of flex. G-10 is strong, but not all that rigid, and folks tend to equate flex with weakness.Invective wrote:Can't thread screws into plain G-10, it's strong but not enough to be able to hold the screw threading. Liners are usually so you can place a non-wire pocket clip, as far as I'm aware.
The OP was specifically asking about G-10, not FRN.twinboysdad wrote:they do...Google search "spyderco salt", all linerless FRN.
If there's a clip on that knife, chances are good it has some amount of liner. You can't tap G10 very well. Even the Dodo which a lot of people think is linerless has a small nested liner for the clip to screw into. Liners also add strength and reduce pivot flex.
Love mine. . .
. . .but the clip screws into G10 and rising collector value made me park it in favor of an FRN Native which has now been replaced by the forum Native 5.
Think Twice, Post Once!
GronK
GronK
I replaced the original clip with a deep pocket clip, but didn't think to look for a liner. I'll have to take a look and see
- The Deacon
There's no liners, it's a midlock. The original version of the Renegade, and the original G-10 version of the Blackhawk, had no liners.Evil D wrote:See...there's a reason the clip is screwed in the spot it's in...that's where the liner is.
That wasn't the Blackhawk, it was the Renegade, and it wasn't exactly a Sprint, more a "found a crate of old parts laying around" run.GronK wrote:They did a sprint run in about 2002 with a liner added but my original has none at all.
The Dodo also isn't linerless, it has a little liner in there :)twinboysdad wrote:and you cut off the rest of my sentences where I stated the Dodo was G10!
A quote from 11/20/2001 by Sal that seems to indicate both were offered:The Deacon wrote: That wasn't the Blackhawk, it was the Renegade, and it wasn't exactly a Sprint, more a "found a crate of old parts laying around" run.
"I just received a sample of the reborn Renegade and Blackhawk models. Very nice.
A few minor changes from the original version;
The "cut out" in the handle to access the opening now is cut out on both front scale (as before) and the back scale.
There is a single stainless liner for the clip screws. I think the fit, finish and general quality are better.
They should be available shortly.
sal "
Also, pics of all three variants in this thread http://www.spyderco.com/forums/showthre ... -completed!
GronK
GronK
- The Deacon
My bad. For some reason, I was thinking they'd only had Renegades finished in Japan.GronK wrote:A quote from 11/20/2001 by Sal that seems to indicate both were offered:
sal "
