Sal, couple of things I thought would be cool to see.
- SteelSpyder
Wasn't sure how else to title this :) . This was just some thoughts I have heard some others talk about and a thing or two of my own.
Possible future Mule steels?
There were a few steels I had in mind.
Aogami White Steel #2. Would make for an interesting comparison between Super Blue to see what kind of differences could be seen.
Vanax. It's large Nitrogen content seems like it would make for an interesting steel.
Something in CPM-154? Para 2 or Military would be awesome.
Sprint run idea. Perhaps an Endura 4 sprint run using the Volcano texture like on the Goddard, and what I believe was also used on the Endura 3.
Just some random thoughts, and maybe to see what else some others think too.
Spyderco's on preorder: Native 5 S110V, Military Cru-wear, Delica 4 Super Blue Sprint.
- The Deacon
I'm most definitely not Sal, but I can tell you that the molds for an FRN handle are very expensive, on the order of $30K-$40K. No way to justify it for a 1200 piece Sprint Run, it would add far too much to the per unit cost and I'm not sure how many would share your love for it.SteelSpyder wrote:Wasn't sure how else to title this :) . This was just some thoughts I have heard some others talk about and a thing or two of my own.
There were two steels I had in mind.
Vanax 75. I believe I heard that Bohler was changing something with Vanax, but it's large Nitrogen content seems like it would make for an interesting steel.
- araneae
Just fyi, There is almost zero chance of a sprint E4 with the old texture. That would require new molds that cost thousands of dollars to produce and would be economically unfeasible.
-Nick
Last in: N5 Magnacut
-Nick
- SteelSpyder
That makes sense. I hadn't really put much thought into how much the molds might cost. I suppose I should just get a 2013 Goddard to satisfy that before they are gone.The Deacon wrote:I'm most definitely not Sal, but I can tell you that the molds for an FRN handle are very expensive, on the order of $30K-$40K. No way to justify it for a 1200 piece Sprint Run, it would add far too much to the per unit cost and I'm not sure how many would share your love for it.
- The Deacon
Great minds think alike. :Daraneae wrote:You beat me Paul.
- RadioactiveSpyder
- SteelSpyder
I thought about that as well. However some changes were made to the handle design of the E3 to the E4. So unless Spyderco was willing to redo a Endura 3 run in full flat ground configuration, similar to the newly released Goddard sprint, I don't see it happening.RadioactiveSpyder wrote:Not intentionally trying to play Devil's advocate here, but wouldn't Spyderco still have the old E3 Volcano grip molds around, given that they've used them previously? Just curious...
- RadioactiveSpyder
Again, Devil's advocate here, couldn't they just do a sprint run of E3's then? I'm pretty sure they could handle the blade switch to a FFG. Now you'd lose your E4 handle upgrade but it would still be pretty easy for them to do, assuming the molds are still available.SteelSpyder wrote:I thought about that as well. However some changes were made to the handle design of the E3 to the E4. So unless Spyderco was willing to redo a Endura 3 run in full flat ground configuration, similar to the newly released Goddard sprint, I don't see it happening.
- The Mastiff
The White steel is probably the rusty-est steel I've ever used. It can be taken care of but it does need care. Many expensive chefs type knives are made from this steel because of the edges it takes but it does need care and the correct cleaning.
I like everything about the E4 model and I'm not sure what could be gained by going back to the E3 setup even with a FFG blade. I still have several of them around and prefer the E4 by a long shot. The Super Blue Endura made a really nice sprint that is a one of a kind project, not having anything that ever made by anyone before. Production wise anyways. There might be some knifemakers in Japan who have made that size knife before but for sure no production quantities, and for sure no modern lightweight high performance models like the E4, the SB Calys before that, and the later Delica, Stretch, Dragonfly etc.
I woulkd worry about pivot rusting over the long haul using White steel. It can rust fast enough to make it a problem over the lifetime of a knife. Even cleaning it without taking it apart as I do with my Enduras could be problematic. Super Blue so far hasn't been a problem for me but White steel is a different matter altogether. All I can do is guess never actually having a white steel folder.
Joe
Joe
- SteelSpyder
Yeah I just thought the volcano pattern would be cool to see. However after being informed on the cost of molds I can see how its a no go.The Mastiff wrote:The White steel is probably the rusty-est steel I've ever used. It can be taken care of but it does need care. Many expensive chefs type knives are made from this steel because of the edges it takes but it does need care and the correct cleaning.
Joe
The Super Blue Endura 4 is fantastic and I am thinking about getting one or even two more. Super blue is easily one of my favorite steels all around. I look forward to all the sprints in that.
I assumed White would be very rust prone like alot of simpler steels 1095, 52100 ect.
Okay. Since my other suggestions are out. Lets perhaps discuss the possibility of Vanax :D ?
- SteelSpyder
The whole reason I made this thread (stating since I am new) is I know Sal is close to his fanbase and just felt like hearing his thoughts on some perhaps bird brained ideas. I post alot on Bladeforums, but prefer the feel overhear.
- The Deacon
They're still using those molds for the Pacific Salt, so sure, they could do a FFG Endura 3. Of course, it wouldn't have the shape, liners, and 4 way clip mounting of the E4 handle. No idea how much interest there would be in something like that, but it would definitely be a lot more feasible than making new E4 handle molds.RadioactiveSpyder wrote:Not intentionally trying to play Devil's advocate here, but wouldn't Spyderco still have the old E3 Volcano grip molds around, given that they've used them previously? Just curious...
- RadioactiveSpyder
It's certainly not that I prefer the E3 handle over the E4, quite the opposite in fact. And I do love the new SB sprint and have even picked an extra one up for a family member for Christmas. As far as the Volcano grip goes, I hope this isn't blasphemous or anything, but I really don't like it. It seems antiquated compared to the bi-directional FRN texture, and I avoid even buying knives with it (gave a Pac Salt to a buddy for that very reason).The Deacon wrote:They're still using those molds for the Pacific Salt, so sure, they could do a FFG Endura 3. Of course, it wouldn't have the shape, liners, and 4 way clip mounting of the E4 handle. No idea how much interest there would be in something like that, but it would definitely be a lot more feasible than making new E4 handle molds.
- einstein2001
A Shirogami Mule would be all kinds of awesome. :cool:
[table="width: 1100, align: left"]
[tr]
[td][SIGPIC][/SIGPIC][/td]
[td]Cruwear Military, CTS-204P Para 2, K390 Mule
Southard, Techno, Sage 2, Gayle Bradley
Super Blue Caly 3, Caly 3.5, Endura and G10 Ladybug
ZDP-189 G10 Dragonfly, ZDP-189 Nishijin Dragonfly
[HR][/HR]:spyder::spyder::spyder::spyder::spyder::spyder::spyder::spyder:
-Brandon
[/td]
[/tr]
[/table]
[tr]
-Brandon
[/td]
[/tr]
[/table]
