bearfacedkiller
Postby bearfacedkiller » Sat May 16, 2020 2:26 pm
Been carrying this knife for about two weeks. Doesn’t get much better than this one!
Woodpuppy
Postby Woodpuppy » Sat May 16, 2020 2:32 pm
Yeah, I’m still bummed I didn’t jump on that one like a chicken on a June bug...
:spyder: My other blade is a Kelly Perfect :spyder:
JuPaul
Postby JuPaul » Sat May 16, 2020 2:43 pm
Sat May 16, 2020 1:47 pm
JuPaul wrote:
Sat May 16, 2020 1:31 pm
autoxer wrote:
Sat May 16, 2020 8:29 am
Sat May 16, 2020 4:27 am
A new one... :rolleyes:
Congrats on having a Manix back in your life! ;) :p Beautiful picture!
Thanks, just wanted to congrat you on your great PM2 pic above too... :p
/ Yes, I am happy to have a Manix once more! And funny, all that contemplating about the G10 Rex 45 Manix and what I really want in a knife, made clear for me that still the LW platform is the way to go for me personally. At least as long as I have already several linered knives like Endura, Stretch, Endela, Delica and Chap.
/ How do you like your orange S90V Manix LW meanwhile?
Well, the lynch clip arrived, but sadly it's too short to help with my grip when closing the knife. If they made a longer one, I think it'd make a big difference. Luckily I like the lynch clip a lot on the para3 lw, so it won't go to waste. As it is, I like the manix lw enough to keep it around and see how much I carry it this summer. It definitely fills a niche in my collection for a bigger lightweight knife, and I do want to give s90v a fair go.
Btw, I have tried closing it as you suggested, but it's very awkward for me. Feels like my hands are too small to grip the lock in that position. But I'll keep trying. :)
- Julia
JonLeBlanc
Postby JonLeBlanc » Sat May 16, 2020 4:31 pm
ThomC wrote:
Sat May 16, 2020 9:15 am
It is surprisingly hefty ! Almost as big as the Millie but only 140gr. It's really good. I didn't think I'd like the CBBL, but day one impressions are good. I'll admit half the reason I bought it is the steel.
That's a totally legit reason to buy any Spyderco! I think a big S90V blade like that makes for a perfect yard work folder :cool:
toxophilus
Postby toxophilus » Sat May 16, 2020 4:47 pm
Tools for the week; CTS-XHP/CTS-204P/ZDP-189; liking these (new to me) Tero-tuff scales :spyder:
RadioactiveSpyder
Postby RadioactiveSpyder » Sat May 16, 2020 6:34 pm
Enactive
Postby Enactive » Sat May 16, 2020 7:20 pm
[img]https://i.imgur.com/ersXjJt.jpg
Very nice. :cool: :spyder: I don't usually go for blacked out knives, but it looks great with the smooth scales. Are those from the KC Cruwear Native or...?
RadioactiveSpyder
Postby RadioactiveSpyder » Sat May 16, 2020 7:32 pm
Thank you, yes it’s a blade swap between the KC smooth G10 Cruwear exclusive and the BHQ DLC M4 exclusive. :)
Crazy Canuck
Postby Crazy Canuck » Sat May 16, 2020 11:17 pm
- Mike
Singing along with the voices in my head
Postby Wartstein » Sat May 16, 2020 11:34 pm
Yes, the LW is a great summer-shorts-knife! :) Light weight in larger size actually "feels lighter" than the same light weight in smaller size, and as a matter of fact light weight in large size is less "bouncy" in light-garment-pockets than light weight in small size.
/ On different closing methods of the CBBL: There are several more I use (for me the CBBL is the second most versatile lock in use, just the backlock is better). Maybe I´ll start a thread on this and try to post some vids.
Perhaps your hands are too small for the one I described, but perhaps I just did not explain it properly?
The basic idea is:
You still pull the CBBL with thumb and index finger,but don´t put the other three fingers on the clip, but like in a "regular grip" around the handle (so middlefinger, ringfinger, pinky on the downside of the handle) - for me that is even easier to do than with the fingers on the clip - ?! (And the knife is more secure in my hand) . but it might not be for your hands of course
Then you just let the blade drop (or give it a little shake if it is not free dropping) like many do with a backlock
From there on you just do whatever you´d do when you´re closing a backlock.
I don´t know if you can pull the CBBL with just the thumb on one tab (instead of two fingers and using both tabs), but if you can here is another method:
- Index finger in the opening hole, thumb on the lock tab, other fingers in the downside of the handle
- Pull the lock with the thumb
- Guide the blade to closed with the index finger while moving the other fingers out of the way in the process
For me both the above methods work as fast/easy or even faster/easier than the usual CBBL closing method ("swing" the blade to close with all fingers out of the way) when I start from a realistic grip you´d use for cutting stuff
bearfacedkiller
Postby bearfacedkiller » Sun May 17, 2020 6:44 am
Slo-mo fire and the Rex Military!
Woodpuppy
Postby Woodpuppy » Sun May 17, 2020 7:04 am
Su-weet! My millie doesn’t work like that :(
To remove lateral blade wiggle, I’ve got to tighten the pivot to the point the blade doesn’t move under its own weight. I can “spydie-drop” it but mostly just thumb it open. Need new pivot washers I guess. Not that I mind; it makes for a very controlled one-hand close.
So I think the washer are too thick, given the interference fit I’m getting. Maybe I could lay them on a white ceramic stone and home them a bit?
JuPaul
Postby JuPaul » Sun May 17, 2020 8:37 am
The basic idea is:
W, I'm starting a new thread on this so I don't derail this one...
- Julia
Postby PeaceInOurTime » Sun May 17, 2020 9:13 am
+ I'm currently participating in a serrated edge only challenge for 2020: viewtopic.php?f=2&t=85560
+ "Wouldn't it be tight if everyone was chill to each other?" -Gryzzl (Parks and Recreation)
Crazy Canuck
Postby Crazy Canuck » Sun May 17, 2020 11:34 am
UKPK today
- Mike
Postby Mushroom » Sun May 17, 2020 1:58 pm
Ready for a Bombshell to drop! ;)
- Nick
:spyder:
autoxer
Postby autoxer » Sun May 17, 2020 2:15 pm
The Meat man
Postby The Meat man » Sun May 17, 2020 3:00 pm
What model is that? Don't ever remember seeing it before.
- Connor
Holland
Postby Holland » Sun May 17, 2020 3:33 pm
This weeks rotation
Junction | Gayle Bradley 1 & 2 | Mantra 1 | Chaparral 1 | Dragonfly 2
Postby Mushroom » Sun May 17, 2020 5:27 pm
[mg] https://i.imgur.com/4zVJQST.jpg [mg]
This is the Chubby by Michael Burch. Definitely lives up to its name at 2.3" blade length and .175" blade thickness. :)
- Nick
:spyder:
Users browsing this forum: Bing [Bot], DDK, Farmer, Majestic-12 [Bot], pantagana23, SeanOD, skeeg11 and 29 guests
