saver salt pin or screw?
Knivesinedc
Post by Knivesinedc »
I have read that the salt knives have been updated to be screw- together construction but, Spyderco's pictures show pinned together. any info??
Relentless Perseverance in the Face of a Lightless Sky.
Joshua 1:9b "Be strong and courageous, do not be terrified, do not be discouraged, for the Lord your God will be with you wherever you go"
brightb
Post by brightb »
I too have wondered this. Will be buying the first screwed one I see! My years old, heavily used orange rescue is my fav work knife. Not keen on "adjusting" the pivot with a whack of a ball peen hammer every so often though (but it does work :)
Bill
Blerv
Post by Blerv »
Best to call the dealer. iirc all Salt knives have moved away from pinned construction for a cost savings/ease of warranty and repair. That doesn't mean old stock doesn't exist though with dealers.
cosmo7809
Post by cosmo7809 »
If your ordering from a popular online knife distributor(NG, KW, CS, KC) im pretty sure you will be getting a newer, screwed pivot model.
Though, like Blev suggests, giving a call is probably the best bet.
Come Join Us Click Here
Bladester
Post by Bladester »
About a month ago, I bought a Tasman Salt. Pivot screw and back spring screw were torx. Flipping the knife over (side that shows "H1" on the blade), these look like 2 caps - rounded appearance - looking like pins. So, torx for adjustment, but appears like pins from the most photogenic side! Adjustment on mine was perfect, so no worries.
--Larry
DRKBC
Post by DRKBC »
I don't know if they have changed, I bought mine last year and it is pinned construction.
araneae
Post by araneae »
most are now torx pivots, just call your dealer to check.
-Nick
Last in: N5 Magnacut
