Been hoping for word of sheath remediation for Enuff
peacefuljeffrey
Postby peacefuljeffrey » Mon Jun 10, 2013 3:28 pm
I haven't seen any kind of response about complaints that the sheath that comes with the Enuff is loose and rattly and enables the blade to get dulled against its interior (and it does).
Anyone have their ear to the ground at Spyderco to know of any plan in the works to put out a suitable replacement? Meanwhile I'll be working on my homemade kydex monstrosity. ;)
"Within this frame an ocean swells -- behind the smile -- I know it well..."
donovanlai
Postby donovanlai » Mon Jun 10, 2013 9:28 pm
I'm very disappointed that's no response from Spyderco at all... :(
Dr. Balloon
Postby Dr. Balloon » Mon Jun 10, 2013 11:13 pm
I have a remedy for the sheath.
BAL
Postby BAL » Tue Jun 11, 2013 4:21 am
Dr. Balloon wrote:I have a remedy for the sheath. First, without the knife in the sheath, use a heat gun to make the sheath very narrow, it will look too narrow for the knife to fit inside of it. Then remove the first rivet on the sheath and take the clip off. Take the knife, and unscrew the first screw on the handle. Throw this and the clip away, as they will not be needed. Then since you don't like the sheath, go try to return the knife.
I have done this numerous times myself. Works every time. Great way to scam a reputable company.
(fyi sarcasm)
Michael Janich
Postby Michael Janich » Tue Jun 11, 2013 7:15 am
Kristi and I have been following the Enuff sheath threads carefully and addressed the issue in a staff meeting a few days ago. We learned that Spyderco's R&D folks have pulled a sampling of sheaths and knives from stock and have developed a testing protocol to evaluate their consistency and the performance of the design. This will include measurements of the knives and sheaths to see if there are any dimensional inconsistencies, close examination of the molded parts, and repetitive testing of sheath retention.
Kristi and I will keep you posted as we learn more about the results of the inspection and testing. Thank you for your patience.
Stay safe,
Mike
Michael Janich
Spyderco Special Projects Coordinator
Founder and Lead Instructor, Martial Blade Concepts
endgame
Postby endgame » Tue Jun 11, 2013 8:36 am
F@$$#$$ scammers rot and die.you make this world so untrustworthy.you should be banned just for posting how to scam spyderco.thanx for the update Mike glad to see you around .
Dr. Balloon
Postby Dr. Balloon » Tue Jun 11, 2013 8:40 am
? If you are referring to my remedy for the sheath, that's what it was, a remedy. It wasn't meant to scam spyderco, just help people.
Mike Sastre
Postby Mike Sastre » Tue Jun 11, 2013 10:11 am
Dr. Balloon wrote:? If you are referring to my remedy for the sheath, that's what it was, a remedy. It wasn't meant to scam spyderco, just help people.
A scam is a scam, not a remedy, and helps no one.
peacefuljeffrey
Postby peacefuljeffrey » Tue Jun 11, 2013 9:43 pm
Michael Janich wrote:Kristi and I have been following the Enuff sheath threads carefully and addressed the issue in a staff meeting a few days ago. We learned that Spyderco's R&D folks have pulled a sampling of sheaths and knives from stock and have developed a testing protocol to evaluate their consistency and the performance of the design. This will include measurements of the knives and sheaths to see if there are any dimensional inconsistencies, close examination of the molded parts, and repetitive testing of sheath retention.
Stay safe,
Mike
Mike,
I very much appreciate your reply and the fact that you folks at Spyderco are looking into this.
May I make a humble recommendation?
The kydex sheath on the Moran Featherweight is an IDEAL fit. Can something be done along the lines of that design, for the Enuff? My biggest issue is the fact that the knife, while it may be held securely enough against falling out, can scratch the edge against the inside of the sheath. The Moran sheath is wide at the spine of the blade but tapers to a V near the edge, preventing the edge from contacting the sheath at all inside. Plus, the way the kydex lip engages the bolster-area of the knife holds it with exquisite firmness.
Thank you again. I look forward to seeing what comes of this.
Respectfully,
Jeffrey
donovanlai
Postby donovanlai » Wed Jul 10, 2013 9:25 pm
It's been a month, any update of the Enuff sheath issue? :confused:
Stay safe,
Mike
donovanlai
Postby donovanlai » Sat Jul 27, 2013 7:11 pm
saw my friend's enuff yesterday, still having same issue, sign…
Stay safe,
Mike
Postby sal » Sat Jul 27, 2013 8:01 pm
We're working on a fix, but it's a mold change so it will take a while.
3f8
Postby 3f8 » Sat Jul 27, 2013 8:19 pm
I received my Enuff H1 not long ago. Just hooking a spot to see how this plays out.
donovanlai
Postby donovanlai » Sat Jul 27, 2013 10:45 pm
Hi Sal, thanks for the info, guess I will need to wait…
sal wrote:We're working on a fix, but it's a mold change so it will take a while.
Users browsing this forum: Accutronman, aicolainen, bearfacedkiller, Bing [Bot], Buddafucco, chops688, JRinFL, PaperKnife, root, S-3 ranch, Senfkarte, Snacktime, SpydieTerp, The Robin, Trevitrace and 41 guests
