Chaparral Strength
Chaparral Strength
The Chaparral is a great knife size,comfort, and one of the best looking spyderco knives the only problem is how strong is the s30v? I'm afraid to cut a zip tie in case I bend or brake the very thin blade . Has any one broke a blade yet ? I would be real interested in seeing a HD Chaparral with a thick blade but still retaining all of the good looks of the original.
- chuck_roxas45
Have you considered a techno?
- senorsquare
- The Deacon
As with most things in life, YMMV, but I've cut thick zip ties and the heavy plastic tags stores use on sunglasses with a Chaparral and, back when I was moving, I cut a lot of cardboard, including a good bit of tri-wall, with it as well. Most of that was straight cuts, but there were a couple 14" circles out of tri-wall to protect a clock.
Consider how thin the blade is on a typical Case knife and compare that to the Chaparral...it's still quite thick compared to a lot of knives out there. Think about how thin the blade is on a SAK. I wouldn't hesitate to cut a zip tie with those blades. My only concern with cutting zip ties is chipping the edge. That's why I carry a multi tool too.
- Fred Sanford
- Leatherneck
Can't speak for the Chaparral, but I have the very thin Centofante (2mm), hollow ground with a deliciously thin edge and I did a lot tougher stuff than cutting zip ties.
Only problems came when it came into quick contact with other steel objects. whoops.
edit: not to mention all the super thin traditional slipjoints and Opinels I have put through the ringer.
They're made of steel, not glass. As long as you manage your force wisely it should be more than fine.
