Page 1 of 1
SB Specialty Metals LLC
Posted: Thu Mar 21, 2013 10:18 am
by N. Brian Huegel
Here is information about a new alloy, PSF27, and production technique:
http://sb-specialty-metals.com/grades/psf27
Posted: Thu Mar 21, 2013 1:01 pm
by mattman
I didn't see any details about the production process, other than the "Spray Forming" in the beginning... sounds like a powder process...?
Posted: Thu Mar 21, 2013 1:08 pm
by Cliff Stamp
Spray forming is a technique which is similar to PM in that basically it reduces the effective ingot size and thus reduces carbide segregation and promotes a finer aus-grain. It however does not achieve the same level as PM but isn't intended to. It is intended to basically be a mid way technique between conventional ingot steels and PM, i.e., if you could not afford PM but had a bit more money than what is needed for ingot steels you could go with spray forming.
Posted: Thu Mar 21, 2013 1:11 pm
by N. Brian Huegel
Posted: Thu Mar 21, 2013 1:18 pm
by N. Brian Huegel
Posted: Thu Mar 21, 2013 3:55 pm
by sal
Thanx Brian, Cliff.
Scott Devanna sent a piece to us. We're making a test mule now. CATRA will be the first test.
